Midweb
  1. Sorted, was a pain but you need to remove the nut and washer on the power cable side and use a 10mm spanner to align the keyway up, thanks to oxygen for there help and fast reply.
  2. Hi I have taken my rear wheel off to repair a puncture but i am having a problem putting it back on I am having a problem linning the two key up and the nut on motor connection side is being obstructed with the gear casing
  3. Thanks all, fitted and working. great to have almost instant replies when your bikes in pieces, gives a bit more assurance that with backup you can do it yourself. Mick
  4. Hi its the one that came with the bike, when you say on the left hand side do you mean at the end of the grip, just move everything along an bit.
  5. Hi I am trying to install the throttle on the above, I have all the parts removed, but I am finding it difficult to find where to position it without it interfering with the gear change, any help or photos would be appreciated. Mick. p.s. I am installing it on the right hand side
  6. Sounds good, found that if I was in the wrong gear the bike would stop and be imposible to start again on a hill
  7. I have been in touch with Oxygen and they say it does invalid date your warranty so they don’t give it out, but I can find it on this Pedelecs forum.
  8. Ive tried you tube it tells you how to do it but not the current code
  9. Hi i am going away next week and hoping to spend some time off road on my new bike. three questions 1. If deristrict it for off road will it void my warranty. 2. does anyone have the two digit code. 3. if I am off road and doing alot of small hilly sections is it best to get the throttle fitted, as I find it verry dificult getting into the correct gear Mick
  10. Thanks for the replies, e bikes direct replied and apparently the step through one in the photo is a smaller frame size than the crossbar one, so I will be ordering the mtb one, same as what you have mentioned plus carrier and mudguards.
  11. Frame size is the same, and I really like the mtb, but trying to decide whether to buy or not,
  12. I am trying to decide wether to buy a Raleigh captus or an oxygen mtb. I prefer the oxygen but wonder wether it is to small I am 5’ 11 and 15 stone, the Raleigh does a larger bike that is more like my none electric one. I have enclosed a picture of me on an oxygen.
