Killerbritt
  1. You a right and the best would to buy a new 36V350W motor! But then i need a new controller and LCD and that would be like 400-500 $.and all the work to install everything! The only thing i want is to get ride of the 25 km/h restriction so i can go 30-35 km/h instead .
  2. Ok, thanks for that. It´s a cargo bike with 3 wheels thats why it´s a 24. I did the opposite and went into the Display sub menu and program it for a 18 wheel and got 4-5 kmh in extra speed, but the bad thing is that the speedometer don't show the right speed. I have the C961 Display and thinking if I can use the BBS02 and BBSHD programing tool to change some settings in the controller! But i don't know if i burn the controller when i connect it! I also upgraded the battery to a LG lithium battery 36V17Ah with cellphone charging USB 3A Charger Bracket. So basically i´m looking for a way to get into the controller and change the settings .
  3. I saw that the picture of controller was a bit small .
  4. Here is pictures of both controller and motor and cant find any data about them on the Internet! But as it street legal here in Sweden then i think the controller is set to 8 amp output! Another thing is that there are 5 cables from the Controller! Battery, 1 brake, Display, magnets,and motor.
  5. I got the BFSWX02 36v250w and would like to know if it possible to put in some more Amps in it? It´s 8 right now but if I raise it to 10 its 300 Watts and 12 It´s 420 Watts, but could it handle that? I want it to go faster and bee stronger .
