darren haggerty
  1. Thank you for your reply Tony, the max amps can be changed in the app but has a ceiling of 15amps set by the profile, I can reduce it no problem just can't go over 15 via the app. The app is fully functioning and so is the blutooth adaptor they work perfectly, I have no wish to return it Tony, but thank you for the offer.
  2. Hi Tony, can you change the max amps from the controller ? Is there a reason your kits are limited to 15amps?
  3. Thank you Tony, problem is I cannot read from the controller using the blutooth connection and I do not have the USB adaptor. The software is from the Nanjing Lishui website, do you sell the USB adaptors Tony?
  4. Hi Whoosh, any chance you could give me the motor settings for the SWX02 48V ?
  5. Hi, just bought my second kit from woosh, a SWX02 48V rear hub and a bluetooth adaptor. I was hoping to be able to set the amps to 17 but the lishui software says it is fixed to 15 amps, does anyone know of a way to unlock this as the controller is 17amps as well as the motor and I could do with the extra torque sometimes. The lishui app has the ability to flash firmware as well as upload a settings file.
