BobbyBrown
  1. Thanks for the reply but that doesn't work. Shame as I'm really happy with the bike apart from the top speed.
  2. I have a Volt bike with a C2 controller and rear wheel motor (same computer is also on a Blix / Ecoride / Velectrix bikes). Anyone have any idea how to remove the speed restrictions? The cable to the computer is 6 pin so the current USB adapters on the internet won't work. I'm reliably informed a set of correct keypresses will get you into the secret menu but I am yet to work this out. Thanks
  3. No, didn’t need to, increasing the pas limit speed worked. Didn’t want to start prodding around to be honest
  4. Seems strange, my C1 is from middle '18 and I've got it to a steady 20 with pedal assist. Also know someone else who has used the above to increase their limit speed.
  5. p.s. with the C2 controller you need a dealer card to get into the menus, from there you can edit the same settings to make the bike go faster. For anyone thats interested: C2 controller, hold + and - to get into general settings. from there hold the mode button and - to get into menu 1 (you need a dealer card) where you can change the limit speed return to the general settings then press mode and + to get into menu 2 (again need a dealer card) where you can turn off the speed at which pedal assist cuts out (should be set at the same speed as limit speed to avoid any conflict with the controller)
  6. No need to disconnect wires, do the following: Turn on bike Hold up and down for 2 sec When in menu up and down again 2962 is the password Menu 6 - should say sys. Press mode Press mode again until you see max speed and change, I’ve done 40 Then hold menu to go back to the main screen (the one you normally use when your riding) Hold up and down again to get into the general menu. Hold mode and down for 2 seconds to enter general settings Password is 0512 Change your speed (LS) at which you want the motor to cut out. I’ve done 32 I think
  7. I am now the proud owner of another Volt bike (the Alpine) that I'll be using to commute to work. Unfortunately this comes with the newer C2 computer that I've not seen before. Does anyone have an idea on how to derestrict it using the controller? I find having an assisted speed of 20mph immeasurably safer than 15mph when battling with the local traffic.
  8. Google ‘juicy bike lcd display’ for the manual. It’ll tell you all you need to know. Remember there is a general settings menu and an advanced menu
  9. Since you posted I’ve had a look around but can’t find the option within the menus. It’s not something I’m particularly interested in as I don’t want to put too much stress on the motor. These bikes aren’t cheap!
  10. Just to throw in my two pence worth... Having had help above I’ve successfully derestricted my Volt Bigfoot that uses the spin tech motor and controller (a computer manual can be found if you search for juicy lcd controller). I’ve not gone crazy with it but just upped the speed limit to 20mph which helps enormously in the flat. The lcd display works great and displays your correct speed - no having to do mental gymnastics as you don’t have to move any magnets around or fiddle about unclipping wires. Well worth thinking about if anyone’s in the market for buying a new ebike and is thinking about tweaking it.
  11. Thanks snip. Worked like a treat on my Bigfoot. Do you know the code for the general parameters settings? I can edit the advanced settings page but I need the password for the other menu so I can increase the limit
