remove speed from samebike 20lvdx30
Check this video. it may help. https://www.youtube.com/watch?v=v0UA8BH2_Jg
LCD S866 + Brainpower controller
Can anyone help with this..motor free wheels fine but when the wheel touches floor and you try to ride ...the bike makes an awful screech and motor seems to be blocked.. Only throttle attached, no brake sensors or Pas attached. Using the S866 display and brainpower 13a controller.
Hi, Just found this on youtube for removing speed limit on Samebike 20LVXD30 Hold right brake and pull throttle fully back and count for 5 secs to remove speed limit and return speed limit if wanted. Check it out and let us know if it works. I don't own that bike so can't try it out. https://www.youtube.com/watch?v=nYngWPc1Zn8
HI, [mention=21598]picusiaubas[/mention]. can you help me find the brake sensors on the Samebike XMZ1214? My motor has stopped working and I have a feeling its because the brake sensors are engaged all the time which is cutting out my engine. I also noticed when I turn the key, the display goes straight to flashing menu 01 or 02 etc which would indicate it thinks the brake is being pulled to access the internal menu.
I've got the XMZ1214. I went for it because of the battery range of 50km compared to 40km of the 20LVDX30. 15APH vs 10APH. And now the speed is increased I'm very happy.
The last 07- needs to go to 0. It's like resetting the system I guess. I was hitting speeds of 30 kph measured on phone GPS speedometer, so a big improvement. It has cut my journey time by 10 mins each way on my daily commute and the bike is so much more fun to ride now! I look forward to it every day!
[mention=21598]picusiaubas[/mention] you are an absolute genius! Just tried your trick and it works! Couldn't test the GPS speed as I was in a car park basement at work, but will do later on my commute home. The power was amazing, I couldn't even get to top speed in the car park as the straight run was not long enough.
I have use the bike in the rain several times now with no problems.
I've got the same bike, same set up. I have a feeling we have a 250 motor rather than the specified 350. Our wheel has 250W printed on it rather than 350W which I can see is printed on Bucio's image. I have disputed this with gearbest.com but have been told directly that it is a 350 motor but comes out of the production line with 250W on the wheel. I have no way of testing this. I am able to reach 25kph using a GPS speedometer to test the speed. Can someone confirm what actual speed you can get from the 20lvdx30. The bike is fine apart from the limited speed.
Hi bucio, did you manage to unblock speed? Also how did you get into secret menu on controller? I have just bought a Samebike XMZ1214 which has same controller, but I can't see any buttons at all.
getgotti
Joined
Last visited
