One for the battery experts- new pack - strange problem- Any advice?
turned up today,won,t get chance to test to test, however three leds lit when I took it out the box and 49v with my meter, funny that the first one didn't even light up and had under 2 volts and took 12 hours to charge, this one only took 3hrs, anyhow won't get chance to run it until next week but I do think I was had off first time. My own fault really,was looking to try these 21700 cells for weight loss and they were the only ones using them, sometimes it doesn't pay to be a guinea pig!!!
My thoughts exactly, funnily enough I haven't been given an answer to that? Going too see what comes back to take that further. I haven't put any feedback on the bay yet so I may be able to do a dispute over this yet
Yes, bit of a case of buyer beware, I have a couple of packs from Jimmy and had no issues whatsoever, if you see a previous post I wanted to save a bit of weight. You live and learn
Bit of an update, my battery is en route back to me after having some cells replaced and a new bms, this is after paying an 88 euro ransom, due to the fact I did my own diagnostic on something they reckoned wasn't faulty in the first place. Once its back and I have tested it me and the vendor will be having one there chats, via ebay and visa. I will be mentioning there name as a warning for others, but to get the ball rolling it's a company that does a lot on the web/ebay and assembles their kit in west germany.
gear sensor led function?
went for ride, seems to work but the cut seems a bit long, might have to tweak the controller delay, early controller so its in the brake switch
This is supposed to do both, will find out tomorrow when I go for a trundle.
just fitted a gear sensor to my bbs02 with an igh, cheap ebay one,any idea on how the led function works. at present mine flashes green and the display unit flickers until I press the shift lever then it turns red, haven,t been for a ride yet but are these things directional, I currently have it hooked up with the wire coming out the back of the unit. anyone fitted one before? thanks eddy
Bit of an update- vendor has sent me a return label to ship back. Will see where we go from there. Thanks for all the help so far. Hoping for replacement rather than repair.
E emailed vendor this morning so we will see what kind of customer service we get. rather they swap pack, will see if I am fobbed off with you checked yourself,etc. They only give 1 month looking at the small print.
Rechecked the pack tonight from B-, the voltages at the sense wires are now B0= 0 BB1=3.81,B2=7.64, B3=11.46,B4=15.28, B5=19.09, B6=22.80, B7=26.70,B8=30.50,B9=30.50,B10=34.30, B11=34.80, B12=38.60,B13=42.40,B14=42.40,B15=46.3. Big fluctuation, B11 stands out at 0.5 volt. Treble checked. little information regarding yesterdays test- I tested the pack voltage prior to removing the bms plug it was 45.9 volts. I checked my readings twice starting at b15 and working back to b1 then from b1 to b15 and got the yesterdays posted values- I wrote a grid up at the time and used this tonight - same methodology. By the look of things I should have done this yesterday as my final test was to recheck the overall voltage which had crept up 46.3. So we seem to have 13 readings- one of which is far from right, and that b8/b9 and b13/14 are wired together. So advise on what to do now really? Vendors advice is to put on a 24hour charge?
Went from B0 on the sense wire, will recheck again tomorrow night, I take it I should be going from B- on the bms board then. sorry in regard to the other reading of the overall pack voltage, it went up 0.4 volts, b- to red on the discharge lead when the sense wire was unplugged.
on checking the voltages at the sense wires from BO- B1=3.83,B2=7.64, B3=11.64,B4=15.28, B5=19.10, B6=22.80, B7=26.70,B8=30.50,B9=30.50,B10=34.30, B11=34.30, B12=38.30,B13=42.20,B14=42.20,B15=46.0. So the voltage on the pack looks good, the lowest cell works out at 3.7 and the highest 4.0 the rest are 3.8 or thereabouts. B8/B9, B10/B11 and B13/B14 are wired into one cell group each. Also checking the voltage on B- to the red discharge lead the voltage has gone 0.4 of a volt. I have a feeling this BMS has the LVC for a higher voltage pack maybe 58/63 volts with it being 15s as the pack is a 13s pack. the vendor advertises this as a smart bms so is it programmable and how. anyones thoughts?
Just had an email from vendor and wanted me to charge up again and check voltage after 24hrs- seems pointless, so lifted the wrap back, its a softpack, to check sense wires, and its been fitted with a 15s 30amp bms, 17 wires in total,checked voltage at b- to pos=45.9 volts. so my next question is 1- is this accepted practice. 2-how do I go about check the sense wires. 3- if this is 15s would the lvc point threshold not be higher voltage and this is the reason it shut down or can this be programmed to suit 13s.? any help appreciated.
update- fitted my old shark pack and back in business - went for a 15 mile ride so email fired to vendor to see were we are going to go with this. will name and shame if I don't get a positive outcome. so far the moral of the tale is I should have stuck with Jimmy the old pack gave no trouble whatsoever if they ok for me to test pack and don't give me the you invalidated w/t -happy days if not I might end up with a rather expensive paperweight if its the cell pack!!
After a reply from the vendor last night of its probably not the battery I am going to plan b- refit my old battery which is a known good one and see if it all fires up- no issues until yesterday. Thanks for the info on the BMS Andy = I was going to go down the road of charging it up again. But what you said makes more sense- due to work it will be later in the week
eddymunster
Joined
Last visited
