mistuk
  1. Hi there, I’ve just bought a Cube Kathmandu EXC bike and it has a Racktime carrier on the back. Could someone tell me if it is compatible with any type / make of pannier or do I need some sort of accessory for it to work with different types? many thanks Kevin
  2. Thanks so much for your message. Can I ask which size you have and how tall you are? I’m 6ft and I’m not near a dealer to try one.
  3. Hi there I’m 6ft tall (a tiny fraction under) and I’m looking at getting a cube bike. I’m confused with their sizing and wondered if someone could help. I’m not close to a dealer so would be getting mail order. My current normal bike is a Giant Roam 2 disc and is L size, I’ve also been on a trek powerfly 4 L size and they are both fine I’m looking at either a cross hybrid pro 625 (which seems to have metric sizing) I’m thinking either a 54cm or 58cm or Cube reaction hybrid exc 625 which seems to be sized in inches - I’m assuming 19” im pretty heavy, would either be better in this case? I really want a Cx motor with 70nm of torque to help with the weight thanks!
  4. Probably should add... I'm look for leisure use. Part tarmac, part off road - but nothing extreme!
  5. Hi there - first post here so be gentle! I'm looking at getting my first bike. Currently have a Giant Roam 2 non electric which I've hardly used, but really want to get into cycling more. Thing that's put me off is it's so hilly where I live and I have no stamina! Looking to lose a bit of weight and enjoy the outdoors more. I think I've decided on getting a Cube (but happy to be persuaded otherwise), but am overwhelmed with the different choices across the range. I think I want one with the Gen 4 Bosch motor as I understand it has more torque, and also the largest battery I can reasonably find - as I'm guessing my weight will reduce range until I can reduce my weight! Can anyone help guide me through the myriad of options, along with the pros and cons? Regards mistuk
