My wheel runs backwards HELP!!!!!!!!!!!!!
- My wheel runs backwards HELP!!!!!!!!!!!!!
Well I am the one who is sat looking at this thing prodding n poking it, so your gonna have to take my word for it. it is as i say it is. Thanks for the help btw- My wheel runs backwards HELP!!!!!!!!!!!!!
if you look at the pictures of the bike vfr put up, this one is set up the same. i think there was confuddlement because i took the picture when the bike was upside down, Mind you I did say so....- My wheel runs backwards HELP!!!!!!!!!!!!!
We could have a little bet here. if you can unscrew the brake drum i would give you the bike. Loose and i want yours? confidant?- My wheel runs backwards HELP!!!!!!!!!!!!!
Do you go to Squires in Sherburn? IF you do Im gonna rock up on the Zipper in my leathers n sidi's then take the thing apart infront of you....- My wheel runs backwards HELP!!!!!!!!!!!!!
OMG Honda riders... LMAO.- My wheel runs backwards HELP!!!!!!!!!!!!!
I have just asked my son who is in the Fleet Air Arm.... He says: shut up. stop being a cock! ? kids ehh. B.Z.- My wheel runs backwards HELP!!!!!!!!!!!!!
But there is no need as everything is on the correct side! all the threads run the correct way. just the same as in the photo you put up.- My wheel runs backwards HELP!!!!!!!!!!!!!
At the min it stands me at £75 i need gear kit and shifter so i guess £120 all in. Came with a brand new battery pack which i am going to rebuild to 42v 10A and fit it without the standard battery case which would only allow for 36v. With left over batteries i may make a rack mount battery . all in all not bad for the cost.- My wheel runs backwards HELP!!!!!!!!!!!!!
maybe so, we live n learn. I dont believe its mounted incorrect as I always thought chain was on the right? And that is where it is. the confusion was the clutch freewheeled the wrong way which wasnt apparent to me at the outset. so i was looking elsewhere.- My wheel runs backwards HELP!!!!!!!!!!!!!
The picture is taken with the bike upside down. Chain on the right brake on the left. The wheel is centered ok. There is no thread on both side though, if you look at the hub only one side comes off.The brake side is intergrated with the hub cover plate to the motor. I have 30-35mm available to try fit a seven speed freewheel sprocket, so that is the next job then cobble the brake kit to be secured to the frame. It did have a single speed freewheel sprocket on so the threads are correct. i just removed it. My guess is the wheel is for a different bike alltogether but im almost there so we shall see how it looks when finished.- My wheel runs backwards HELP!!!!!!!!!!!!!
Done. Still no wiser what the motor is though. SO. the clutch. I took the grinder and opened the back to find a SMJR spring mounted jamming roller ( made up terminology ) remove the spring wedge the roller tight-weld Job done. Hope it helps someone in the future.- My wheel runs backwards HELP!!!!!!!!!!!!!
My wheels no longer runs backwards.....As explained someone cobbled the motor together unknown to me, the clutch freewheeled the wrong direction. the cure was open the clutch mech and weld it fixed, no clutch. job done. A little bit more digging on this forum and I have the perameters set up and working a treat. If anyone wants any pictures of the clutch fix let me know.- My wheel runs backwards HELP!!!!!!!!!!!!!
Anyone want to buy a clown ebike?- My wheel runs backwards HELP!!!!!!!!!!!!!
Well Having striped the motor down and powered it up out of the wheel hub it does indeed spin both ways. the gears however have a one way clutch! quite how this motor ever worked with the chain gear on the normal right hand side is a mystery. Maybe its the Australian version . Bin Fodder i lost the will to live lol - My wheel runs backwards HELP!!!!!!!!!!!!!
Back to top
