smcg started following Wsmith8007
Battery question
Cheers I thought I had a dodgy battery most appreciated
Battery question
Hi last question for a while when I charge my bike it goes from red to green for full charge but about 10mins later if I plug charger in it goes back to red is this normal or is my battery losing some of its charge
Battery question
Spot on it is the 48v 10ah with throttle and theres no way that this bike does 20km on pure electric i noticed bike was squeaking whilst riding lifted front wheel and noticed it did nt spin at all i did the release brake trick and now its spinning fine i also pumped the tyres up they were 10psi under will these factors improve distance and by how much roughly i have ordered spare battery but will the weight of the second battery being carried on rack youse more power from origanal battery cheers
Battery question
Hi i took my samebike lv20 out the other way to check distance it did 18miles with pedal assist some hills but not really steep from a full charge the manual says its supposed to achieve double that i know its not going to do 30miles on one charge but 18 / 20 miles dos.nt seem enough so my question is am i still using battery power when the ignition key is on but freewheeling or do i have to turn key off to save battery life it dos.nt answer this question anywhere on line cheers will
Samebike e1 20inch wheel electric bike
Ok when the bike arrived I turned it on straight away it came about half full batt so as soon as th motor kicked in I thought I was pedaling the bike but because the chain was not actually on properly it was.nt me propelling the bike it was the motor so even without the chain on when motor kicks in you think you are using the pedal assist when in reality your not even pedaling the bike weird hence I was using the batt all day but infact it was on pure electric that's why it ran down when turned off chain was.nt on properly all fully charged and working great now thanks for your interest. This forum will be great for bike problems cheers
Hi your gonna love this I just got in from work and I thought I'm gonna have a real good look at this crankshaft and basically under one of the chain teeth was a bit of the bike packaging polystyrene that was lifting the tooth off the chain pissed myself laughing everything working fine now cheers for replying it could only happen to me
Hi ive just bought this bike and everything is fine with power on but when i turn power off ir run out of battery this bike will not pedal forward the front cogs just goturn around with no motion is this normal ir a fault thanks
Wsmith8007
Joined
Last visited
