sdf
  1. Brilliant, thank you, just tried it and they are back to normal.
  2. Hi all I've just bought a Wisper 705 - very pleased with it but noticed that after my first ride (only around 10k) there was more play on the rear brake lever and I'm having to press it further down to activate the hydraulic pads. I thought I could adjust this myself but immediately discovered that the brakes are not mechanical (i.e. no wire to adjust). Does more mineral oil need to be added? The shop I bought it from it is a 2 hour round trip away so I'd rather save the time and do it myself. Thanks for any help/advice. Cheers S
  3. OK, thanks for that. need to find out if my local shop is open to go and test. Cheers s
  4. Hi, thanks for your help. The only ebike i've tested was a Woosh one a couple of years ago and then i put it on hold. Presently, covid hasn't helped testing wise. I suppose my only other question is wheel size. I'm 5' 8" so does a 26" vs a 700 cc wheel matter. My nearest bike shop, Evans does have a 46cm (700cc) wheel in stock, otherwise it's a long wait. cheers S
  5. Hi I've got a budget of around £1600 for a bike which will be used solely on roads for shops etc. I've got my eye on the following: Raleigh Mobus Lowstep 2020, a Whisper 705, Pendleton Somerby, Cube Town Hybrid One 400 or an Elops 940. I'm after a classic looking bike vs a road/mountain bike. It seems that options are running out as stocks are becoming fairly low. Any help/suggestions greatly appreciated. Thanks S
