Gingerbob
  1. Switched to a different one recommended on here.
  2. Hi folks my anti rotation washer snapped in two yesterday. Anyone know where I can find a replacement. I don’t think a torque arm would work.
  3. I have had 2 of these sensors break. I’ve now replaced it with a magnetic cadence sensor and a throttle.
  4. Yes all sorted now. The full manual was great. I put c1 to 7 for the 12 pole pas I bought separately from the kit. Cheers.
  5. Ah I’ve found a manual. My kit came with a single piece of paper with the basics on it.
  6. Hi Nealh how do you get into the settings of the lcd? I see lots of posts about c and p numbers but don’t know how to change these. Reason I’m asking is PAS isn’t working. Led on sensor flashes but motor doesn’t kick in and I assume I need to change a setting. thanks.
  7. Ah. Ok thanks for that.
  8. Hello my helpful pal. I have connected everything up in a test version and it’s working great first time. Only niggle is that it maxes out at 20mph even though max speed is set to 72kph. Any ideas why? But anyway thanks for holding my hand during the buying process, much appreciated.
  9. With an additional 12 pole pas.
  10. Ah I see some with 12 pole but not in the kit.
  11. I can’t see a 10 pole pas. There is a Kt-by-waterproof that’s got 6 signals.
  12. Sounds exciting. Yep no problems on either account. I can strip a bike and I’ve built my own quadcopter. Where do we begin.
  13. Hi. I have replaced this before and the second one just broke. I would love to rewire this setup with a derestricted throttle. Any idea what controller would work?
