Anybody selling a thru axle
Thru Axle 12mm 148-180-20-m12-p1.75
Bike advice quick release thru axle lever videos included
pure electric did it!! they got it out with Halfords Self Grip Pliers 210mm
- Bike advice quick release thru axle lever videos included
I'm not followed by you, could make a video showing us???- Bike advice quick release thru axle lever videos included
like these https://www.screwfix.com/c/screws-nails-fixings/nuts/cat840096?boltsize=m6 or these https://www.orbitalfasteners.co.uk/products/m6-x-18mm-studding-connectors-stainless-steel-a4 these https://www.wickes.co.uk/Wickes-Studding-Connectors---M6-Pack-of-6/p/156642- Bike advice quick release thru axle lever videos included
Hello my thru axle was installed for the last time before breaking here the installation thru axle before it broke then after me explaining in the video and the issue as it stands now. the issue im looking for a solution to get this axle out, plan to go to shop monday. the issue written which can be seen and heard in above videos. Installed the thru axle i always do, attempted to take it out at a stand. the axle level came off, screwed it back on it just came off again. im looking for a solution on how to remove the axle out if anyone knows how.- Bike advice quick release thru axle lever videos included
Hello my thru axle was installed for the last time before breaking here the installation thru axle before it broke then after me explaining in the video and the issue as it stands now. the issue im looking for a solution to get this axle out, plan to go to shop monday. the issue written which can be seen and heard in above videos. Installed the thru axle i always do, attempted to take it out at a stand. the axle level came off, screwed it back on it just came off again. im looking for a solution on how to remove the axle out if anyone knows how.- Get the correct wheel replacement for bike wheels
Thanks- Recommendations
also this bike offer 340% pedal assist- Recommendations
Explain because i'd never type what your typing right now- Get the correct wheel replacement for bike wheels
Hello im using Schwalbe Ice Spiker Pro HS379 DH Black 27.5 x 2.25 on an haibike trekking 8.0 2020 with a cassette shimano 12 speed do a you have wheel or wheel set that'll fit these my axel is length is 15mm- Recommendations
Best bike reccommend form uber eats/deliveroo/stuart/just eat rider haibike trekking 8.0 2020 2000+ miles only had to replace pads and crank arms (slide and fell on some smooth cobble ground resulted in bent cranks easily replaced ) worth the investment- All emtb ebikers which one is the best for my job!!
Yeah thanks went for the 8.0 trekking im the end- All emtb ebikers which one is the best for my job!!
Haibike trekking bikes are capable - Bike advice quick release thru axle lever videos included
Back to top
