MartinRoach
  1. Thanks, my battery is 36v and slides underneath the back Rack, maybe it can be re-used on the next bike ?
  2. Thanks Gavin, the ‘bike shop’ said that the motor was knackered ( I couldn’t hear it rattling because I’m very deaf). they seemed genuine & didn’t charge me for looking at it. I’ve spent hours just trying to get the motor working. i agree with you about the environmental waste aspect but, I‘ve dismantled nearly everything so far & because it’s so old I think it’s time to buy another. the owners at batribike don’t have parts or wiring diagrams, the shop calculated the cost of repair, the mechanical parts are very worn, I’ve had to fit umpteen spokes, the tyres & brakes need replacing, chain, sprocket and Handlebar gearchange. its sad, but I think the bike’s done it’s work & needs retirement. if you think a pedal assist bike could be adapted to allow turn n go throttle that would help? kindest regards, Martin
  3. I live in St Anne’s, Lancashire. The bike is quite old so I’m considering a replacement. Perhaps you know if a new bike can be adjusted to work without pedalling? if so, could you recommend an easy to get-on bike ? kind regards & thanks martin
  4. You have been tremendously kind. I have taken my bike to a dealer & he says it can’t be fixed It’s a pity,as I’m disabled & can’t pedal. The old bikes like mine are ok as throttle control is Ok on a bike before the new rules. Shame. Thank you ALL for your kindness & time to share your knowledge with me . Cheers Martin
  5. Great advice, yes 0v red / black. I’ll try your advice but will the multipin from main controller to handlebar control carry 5v on the red/black wires? cheers Martin
  6. Many thanks, I did disconnect the throttle, tested it,but it made no difference. Thank you very much . Martin
  7. It fell over a few hours earlier, but worked fine afterwards. the following day it didn’t work. there wasn’t even any resistive feel to back-pedalling which would normally brake & recharge the battery. hope this helps ? kind regards martin
  8. I have a batribike diamond that suddenly stopped working. the battery is 36v with 40v tested unplugged after charging. all the leds on the handlebar controller are lit (fully charged). there is no voltage to the throttle (should be 4.3-5volts) if I disconnect the Handlebar controller at the main Controller then reconnect it the motor runs at high speed . i don’t have a wiring/fault finding diagram & I’m not sure how to find the actual fault after trying for hours. can anyone advise/help me out ? kind regards, Martin
