Torridtime
  1. Thanks guys off I go to try and fix.
  2. Thank you for the reply. I also noticed there is a tight spot, on the rear whee rotation. Everything is fine all gears working 16 speed. As long as I don’t wind back the chain wheel.
  3. Hello guys. I have a problem with a Wisper 805fe. Yes it is an old bike but I has served me well for about eight years and still like new. I am 79yrs. Why when I wind the pedal back so it’s in an easy position to start off, while doing this I am turning the pedal and crank does it throw the chain off.
  4. Hi. I have original equipment. Three stage lights on the left handlebar. Low medium high.
  5. Thanks to the two members that steered me to Jimmy and his sone toget my battery rebuilt. Great service all the way. So I have an 805fe Wisper, updated 14amp battery and it’s going great. Can the bike be fitted with a twist throttle and new grips. Or would it be to expensive to change.
  6. Hi. I have had this folding bike from new . It developed a fault. Loosing power after a mile or two, also going up an incline. I asked a question on here, with the age of the battery could that be the problem. The battery was a 9amp one, I have had it rebuilt to a 14amp spec. I have yet to get it from the Ebike folks. But someone suggests it could be a controller problem as well. I don’t mind having the battery rebuilt , seven years use is great I think. Would you upgrade to a 16 amp from 14amp controller. When the power went, if I stopped and switched the battery on and off, it always returned.Can You advise.
  7. Hi I have a Wisper 805fe original battery. What is the best battery upgrade. Please
  8. Torridtime posted a topic in Wisper Clinic
    Hello David. I have owned the above bike for about six or seven years. It has been a wonderful machine. It has started loosing power under load.All lights go off , if you stop riding switch the battery switch off and back on, the lights return and power resumed. If it is the battery can I upgrade for longer distance. I would also like to add a twist throttle, is this possible. Thanks.
