Tongxin motor troubles
I am running it in a 26 inch wheel. I am using Lipo nano Turnigy 4000 mah 5s 18.5v x2 link here. The controller not sure of the make it all came second hand (unused) but it is 15amp I believe.
Thanks for the quick responses I was thinking of a cute wonder if I can use the same rim. What's currently the best source for cute motors? Cheers
As some of you may remember last year I built a lightweight electric bike around the Tongxin motor and lipo nano. Ive had great fun running it with no real problems. Suddenly today while on a longer than usual run there was a metallic crack from the hub then that was it no power. The wheel will spin with no load but only very slowly. Is it all over has the hub given up do you think? Any pointers welcome.
Tongxin 260rpm anyone have?
That's interesting so more volts do equal more RPM even on a hub rated at 190rpm. I am currently running a max of 36V which tops out at 15pmh
Looks like a minimum order of 100 from the Outrider link. What's wrong with putting it on a 26" wheel is it a speed/torque issue?
I am wondering if anyone has one of these motors they wish to sell. I have built a little bike see this thread.. It works really well but tops out around 14/15mph so I would like to try the faster spinning motor. Thanks in advance.
Nano batteries with Tongxin
Thanks for all the technical info you guys know your stuff. I can see why these batteries are not used in commercial applications just overly complex for the average user. I think if I do build a few bikes for people then I would go down the BMS Battery route it seems a good way to build a competent electric bike on a budget. I like the look of their frog batteries they seem similar to ones used by Electric wheel and other components seem to be used by other electric bike resellers. My bike has evolved slightly in that I now have an IP68 plug in the top of the battery bottle and the weight is now 13.6kg. I have to say its an absolute joy to ride and really zips around 0-15 in just a few secs up the hills no problem at all. I'm just checking out the range now up to 8 miles and 3.89V. Who knows with enough interest I may turn it into a little side line business based in Exeter, not sure if there are any members in the southwest?
I've just done 4 miles and tested the batteries and they are showing 3.9v. Better news, I've also just ordered the cellog 8m so looking forward to getting that. As an aside I've had a fair amount of interest in this bike and a couple of requests to build similar lightweight machines. I may be doing some more.
Thanks for the info 3.4V seems like a high number if they are full capacity at 4.1V. I checked mine yesterday after about 5-6 miles and they were at 3.7V all roughly the same. Charging took 1.5hrs. Will look into a CellLog
I've changed this now so the wiring is encased in rubber, allowing the controller to keep cool. I probably won't use this bike in really bad weather. I currently have no method of monitoring each cell on the bike, when I charge the batteries I can see how the cells discharged and whether it was even. I could invest in a cycle analyst but they are pricey and I don't think it can monitor each cell. Not even sure how this could be achieved.
Cheers guys, these batteries seemed to have no problems under load nothing go warm. I picked the nano lipos as they seemed to have a good spec, lightweight, very little resistance and therefore not be too stressed under load. They also apparently have twice the life cycle of a normal Lipo battery. This should be an all weather bike (hopefully) as I intend to encase the controller and wiring in rubber. I need to improve on this part of the project and also put in some sort of plug so I can disconnect the battery bottle easily. http://www.dhdesign-uk.com/bikes/IMG_0846.JPG I will also black out the hub to make it look at bit nicer.
First run Well after spending a good few hours in the garage leaning how to solder putting all my EC3 plugs on then soldering wires heatshrinking then Anderson connectors I was ready to test out the system. Battery charged and checked all wiring ready, connect the batteries, flickering red light at the throttle and NOTHING! Phoned Alan (sorry Alan thanks for listening) had another look at the fuse and it must of part blown 15amp fuse, I believe the controller is limited to 13amps. Changed the fuse all good wheel spins. The set about routing the cables along the bike using some half round PVC trunking and cable ties. I than made up some rubber sleeving to go around the controller and to keep the top of the battery bottle on. [ATTACH]2765.vB[/ATTACH] [ATTACH]2764.vB[/ATTACH] Finally got it all up together this morning weighed it 13.8kg bit heavier than I was hoping and took it for a test ride. All very nice and smooth, I have a steep hill just round the corner so went up that relying more and more on the motor to see how it coped. All good until it popped. The fuse again well to be more accurate the fuse holder. Close inspection revealed it was rated at 10amps. Need to find a better holder! [ATTACH]2763.vB[/ATTACH]
All the bits have finally arrived - thanks Alan for the hub and wheel etc. The batteries won't fit into the expensive Camelpak bottle so I've got an aluminium one now and cut the top off it. Really nervous now though as the batteries come with next to useless plugs on the end and won't even plug into the Turnigy charger. I have to cut them off and solder on some EC3 plugs all new to me. Thanks Amigafan2003 I pretty much copied your list of supplies. So assuming I can get the plugs on and charge the batteries worried I'll do it wrong, the plan was to connect the batteries in series and then charge them using one of the two balance plugs. No idea which one so I may just charge them separately on the balance board for now. Then its the wiring up, probably straightforward as the (unknown controller) is prewired with Anderson connectors, I may ditch these as the are pretty fat and would need waterproofing. Lots of fingers crossed!
I guess range is subjective when potentially so many factors are involved. The only true measure must be an average speed throttle only on a flat run. Following on from earlier in this thread I wonder whether a lighter bike will have a significant increase in range. I think I will have to invest in a cycle analyst even though they are quite expensive. My batteries are going onto a plane in Singapore.
That's a pretty powerful pack, what kind of range do you think it will give? I've only ordered x2 5s 4000ah packs but am hoping for around 20miles assisted
Dadplus2
Joined
Last visited
