Battery repair
I’ve got a Wisper battery that is faulty, it won’t charge now, and recommendations for repair please ?
Wisper rack battery waterproof cover
Great suggestions
Yes it’s got mudguards front and rear
Hi all, I’m riding a Wisper with rack mounted battery / BMS ... does anyone have any recommendations for an elasticated rainproof cover for the rack / battery for riding in wintry / wet weather .... perhaps a backpack cover or similar .. just trying to keep most rain off the important bits .. also if anyone has a good temp transparent mini cover for the handlebar control unit .. thanks
Cross bar adapter for 21kg step thru ebike
Hi all, I’m trying to find a cross bar adapter / false crossbar for a step thru ebike that weighs 21kg ... many products are rated for only 15kg ... anyone have a solution or product they have found ?
How to carry a 2nd / extra battery ...
It’s the 2nd option ... transporting a spare battery so I can remove the 1st exhausted battery during a ride and slide in the 2nd so I can continue, with renewed range. So far, I have started to use an old laptop bag to bring one / both batteries from the house/flat to the bike so that they are protected from bashes and risk of dropping. Next I’m favouring the idea of doing the same with a rack mounted bag, so I can pre prepare, snacks spares and tools too.
Just trying to do research on the best way to carry a 2nd / extra battery. If anyone is already doing this, please share how you do it and any advice you have ?
Just turn by turn
Hi all, I’m just looking for a device that does pre planned turn by turn navigation. Preferably with a simple LCD screen. Any simple options ?
Stuck at the lights
Get off the bike and lean it over almost flat, that exposes enough metal to trigger the sensor, just needs a bit of practice
Whoosh Rambletta or Wisper 806 ?
Any comments or recommendations on the choice between Whoosh Rambletta or Wisper 806 ?
Dahon
Hi all, can anyone help / advise. I need to convert a Dahon folding bike (Vitesse D7). It has 20” wheels and the front forks have approx 74mm dropout. Can it be converted ? Thanks.
Trod
Joined
Last visited
