TonyT28
  1. I usually go riding with 3 friends. Does anybody have and suggestions as to what would be the best radio mic system for 4 riders. We are all pensioners so the budget is pretty limited. TIA.
  2. Thank you, if it is old firmware I might invest in a new controller.
  3. Hi, I have just purchased my 1st E-Bike. I’ve not been on a bike for about 50 years, I’m 68 now so all this is very new to me. When I bought my bike it was in a bit of a state. The bike is a Carerra Vulcan with a Voilamart conversion kit. It took me ages to find out out what the motor was as it has been sprayed and doesn’t have any decals on it. The LCD was cracked so I could see any settings on it. I had to switch it on and count the number of times I pressed the up button to “guess” which number pedal assist I was using. I have since bought the same LCD as was fitted on the bike. I eventually found it to be a KT-LCD3. I am happy with most of the settings but have a few issues which hopefully someone can advise me with. I have tried using the setting for the battery on level 15 which apparently is the default setting for a 36v battery. When using it set to 15 it does not show the battery to be fully charged, although it is. The very first segment does not light up. I changed the setting to 0 and it then showed a full battery. When using this setting I notice the battery level to be fluctuating, sometimes dropping to 0. Is this normal? Another issue is when using pedal assist the power seems to overrun by about 1 or 2 seconds when I stop pedalling. My last question is when the motor is under pressure it makes a very strange noise, it’s not a grinding or crunching noise, just difficult to describe. Does anyone have a clue what it may be? Sorry for the long winded post.
