mga
  1. can anyone give me address where I can obtain these batteries regards ken
  2. many thanks for your prompt and helpful suggestions and suplimentary data. I conducted a test of the battery under a 10 amp load ( electric fire element )and found that after 17 minutes the battery cut out having dropped to34 volts this is in line with my experience with the battery attached to the cycle i am therefore returning the battery under guarantee to the supplier in china one or more cells are faulty or the bms is cutting in too soon i think it is the former thanks to all for help. I would mention however that i object to being called an idiot by frank just because i am unable to afford an english battery needed to help my medical needs to continue cycling
  3. I have an ezzee cadence cycle and have recently (last month) purchased a new chinese battery 36v 15 a fitted to the cycle carrier i charged battery end went 5 miles in green and yellow light mode before battery failed i then recharged battery took 2hours to fully recharge and then went out again same result red light never appears. Switching on then off brings a positive result until yellow light goes on and then drive stops and light next to key goes out. Light next to key flashes 7 times when battery charge is at an end. Any help would be appreciated ken
  4. battery and charger arrived from china yesterday slight damage to charger despite careful packing however both items have been checked and seem to be ok parcel delivered by ems and parcelforce no vat or duties to be paid !!thanks for advice i now have to work out a method of fitting them onto an ezee cadence in the most efficient and visually pleasing method although the original battery was 10 amps i have purchased a 15 amp model hoping for a longer life battery Price difference was not too different price paid including charger 36v 15amp battery and bms including free delivery was 299 dollars/ 191 gb pounds ken
  5. many thanks for advice i have taken a chance and ordered it I willl let you know outcome ken
  6. what is the up to date position regarding duty and tax from this country any one who has done this please advise thanks ken
  7. ezee cadence many thanks flecc batteries are shot i now have to work out how to get alarger battery into the original case. the switch for lights is still there but bulbs have gone could you advise me of volts/watts of front and rear thanks again ken
  8. I have just purchased an ezeecadence with two faulty batteries. I took both sets of bateries out of the plastic case testing them for voltage and amperage picking the best 10 cells to make one battery this has had vrery limited success,from two dead batteries the " new" one wil ltake me 4 miles having a spare bms and a case i want to recell the second battery but i am having great difficulty finding cells or battery pack that will fit inside the plastic case Any help gratfully received. While i am on how do lights work is there a switch? Batteries have a sticker 08-10-05 one case siver with 50 cycle sticker one red with no sticker lithium ion cells x 10 at 3.6 volt 10 ah
