Rt3005
  1. Plas man started following Rt3005
  2. Rt3005 started following peter.c
  3. i put a 42t on the front but even with that, however I set up the derailleur I can't get the bike to stay in a gear, it just jumps up and down out of gears
  4. So regarding the gearing, are the gears on the back wheel meant to be offset with a spacer to mesh properly with the motor?
  5. Did you remove what was already on the dnm? I'm not sure how to.
  6. What hardware did you use to fit the dnm aoy to the back mount?
  7. The awkward fiddly game in town haha. Still haven't got mine together
  8. So wont the valve closest to front of the bike impact with the bracket on compression?
  9. Can you post a pic of the L frame with DNM AOY shock? I cant see how the valves wont get in the way.
  10. Hmm so with battery i have i dont think i can use the other mount
  11. Link to the second type of mount you think will fit?
  12. Its an aluminium SAB frame.
  13. I was wondering if the basic hub motor kits can be adapted or fitted with controls that actually fit on road bike handlebars?
  14. What is going on inbetween the top suspension bracket and the battery? Have you connected those somehow? On the xl i mean.
  15. I think that's what your frame is from. Slightly different rear swing arm and suspension mount to mine.
