Teesebike
  1. I had error 10 the other night on a brainpower controller paired with s866, I tried each and every way I could to get it going with no luck. I have looked on Amazon at the reviews and they aren't great for the s866/brainpower combination, a lot of people not managing to get them working. I'm wondering whether your only getting 16 settings due to a limitation in the controller you are using as I was getting 21 p settings on s866 with brainpower controller. No wonder people always advise getting a kt controller/lcd. The s866/brainpower controller I fitted prior to the one the other night worked great with no issues whatsoever so they look to be a bit hit and miss.
  2. Another thing you could try is hold down + and - on the lcd until you get the p settings click power each time to cycle through until you get to p20 and see if you can change the communication protocol if you can try it on each setting to see if it removes error 10
  3. I have an s866 display here and I've just been looking at the connector and noticed the colour code is different to what is coming from your controller did you match the colours ie chop and reattach or just plug staright in? I've noticed on the s866 + and - are on opposite side of the connector which is confusing if you have directly plugged it in. The s866 is generally sold with the 350w brainpower controller where the connector colours match like for like.
  4. Do you have a picture of the wiring come from your bike? The wiring which was connected to your original controller? I can probably suggest a controller once I can see the wiring, error 10 on the s866 is a communication error which can be caused by linking it up sensorless, ie. Using just the 3 thick phase wires usually (yellow, green, blue) and not connecting the square hall sensor multiplug. Once I see a picture of you wiring the situation will become clearer.
  5. Hi wonder whether anyone has come across this before, I am wiring a brainpower controller into a folding bike I have, the wheel seems to be spinning slower than expected but also the faster you pedal the faster the motor turns slower pedalling = slower motor. It seems a possibility is a may be wired into the throttle wiring but didn't expect it to work at all when wired into throttle wires.
  6. I've just got a 36v brainpower controller and s806 lcd working on the original cyclamatic power plus it was easy enough to figure out Motor Brushless Controller + LCD Display, Rainproof 24V-48V Electric Bicycle Scooter Brushless Controller Kit https://a.co/d/eIhvYyH
  7. I'm just wondering whether anybody can identify this socket on my battery as I'm trying to get the correct connector to fit it. The battery is from a juicy roller and the socket was used to connect between the battery and the bike (probably controller)
  8. Just interested to know what the battery connections like on the battery? Does it have an marked plus & minus? Thanks Carl
  9. Hi I know it's a long shot just wondered whether anyone is a previous bicycles4u employee that could possibly help with a technical problem I have regarding my throttle not working
  10. I'm sure if you use throttle fully twisted for either 6 or 8 seconds it should automatically activate cruise function, leaving ho of the throttle and then a slight twist will deactivate it.
  11. So ultimately [mention=35530]lightning[/mention] unplug all your looped connectors on your new controller and you'll get the fastest speed with the setup you have.
  12. Hi I'm just wondering if anyone is aware of how to enter the advanced settings on the c600e usb lcd, I have a feeling by using a combination of button presses I may have accidentally entered those settings and disabled my throttle, the problem is I don't know how I have done that and what the button press combination is to get to the advanced settings.
  13. The last KT controller I had, had looped wires which could be plugged or unplugged, one was for cruise function, one was for self learn and the other was a speed/power restriction wire. These wires you will notice will basically come out of the controller and go back in the controller, I found the speed difference when I unplugged one of the 3 which gave about a 4mph increase. I think white is usually self learn which leaves you with the other two I just unplugged both so I can't 100% tell you which belonged to the speed restriction and which to the cruise function. Unplugged = faster/unrestricted Plugged in = slower/restricted
  14. Hi I'm looking for some advice if anybody could help. I have just recently purchased a second hand bicycles4u folding ebike, when purchased all was working fine until I decided to have a look through the settings on the c600e usb lcd, after doing so the throttle is no longer able to function although everything else works fine. Although this problem occured after looking through the settings, I am beginning to think think this may just be coincidental and actually a wire may have broken. I have opened up the area on the frame where the controller is fitted and looked at the wiring and all seems intact. I have noticed the throttle wire in the controller area is only showing as 2 colours purple and grey plugged into a usual 3 pin red/white and black from the controller, the ground wire from the throttle is not wired into the connector. Looking down the frame I have noticed the wire from the handlebars seem to run through what looks like some sort of multi plug so I'm assuming the throttle ground maybe shared inside the multiplug with the lcd. I had a working 3pin thumb throttle with matching colours lying around which I wired to a 3 pin connector and connected directly to the throttle plug coming from the controller and tried that but got no joy. Any help would be much appreciated
  15. Yes it did seem a little bizarre as I hadn't done anything other than play about with settings prior to the throttle not working. The settings I can get into on the C600E usb lcd are quite limited though although I did try multiple button holds to see if I could find more advanced settings which I couldn't.
