ampy started following Where to buy a Julet power connector? , De-restricted eBike won't go over 18mph , What is this black and white wire for? and 1 other
Wow, thanks Saneagle! I have dual voltage LCD and KT Controller (7A / 15A) , so I need to look for a 48v battery.
Thanks for the info. The motor has code RM G020.250.DC 31 1. stamped on it.
Hi, I have an ebike that's got a Bafang 250w hub motor, 7A KT controller and a 36v battery. I set the LCD controller to max speed (about 40 mph i think) but the wheel won't spin faster than 20 mph when the bike is on the stand, 18 mph riding it. Is that normal what could be holding it back? Should I upgrade something to get it to about 23 - 25mph? Cheers
Hi All, I was looking at the cabling on my ebike controller and i saw a black and white wire joined together. I disconnected it, powered on the bike, the display came on but no power to the motor, then the display went off and I thought I had damaged the bike. But I reconnected the wire and it seems fine now. Does anyone know what it's for? Thanks
I checked and its Julet. The julet.cn website is down and I don't see an archive of it anywhere, it's like they have never existed... weird.
Hi All, Where can I get one of these Julet power connectors, I looked on Ebay, Aliexpress and searched Google but I can't find them anywhere. If anyone can point me in the right direction that would be great. Thanks
- Voltbike Pulse with Bafang hub motor derestrict help
Oh that's interesting! Can you give me a link to the KT kit as I think that would be an option for me. Would swapping out the controller and display be "plug and play" or would I need to solder and crimp wires? I ask because it's brand new and if I need to get it repaired/serviced I would need to swap the original parts back in for that. Can you recommend anywhere when I can read or a youtube channel that shows how the controller, display, BMS etc all work together, my hobby is electronics and computers so should be ok for me. It's deffo a Bafang motor, see the attached pic.
Hi All, I just bought a Voltbike Pulse, it has a Bafang hub motor RM G020.250.DC. I'd like it to go a little faster and I'm looking for the best way to derestrict it. I can't seem to see any service mode I can enter to adjust anything on the display. Would I need to replace the controller and display with ones that can be modified or is there another way. Thanks for any information.
ampy
Joined
Last visited
