I have the L6 display with throttle and i have already used that code to derestrict the ebike and the top speed reached is about 39-42kph on flat.The ebike was bought from France.So from the display i think i can adjust almost all parameters and I understood that when you derestrict the ebike the controller outputs is 22amp. So 22amp x 48v=1056W peak power. The only problem I have and would like to solve is the lagging when i use pedal assist.You said you can fix that without changing the controller. I also saw that tuning chip from Germany where it is said that you can have a higher acceleration, but firstly, it is much too expensive, secondly, from what I have read, it does not work with the L6 display, which is already an unlocked display.
