Hi,
I read that step through bikes can bend when cycling uphill. Should I get off the bike and walk when it's uphill? I have a Haibike Trekking 4 low step as seen here https://www.haibike.com/gb/en/electric-bikes/electric-trekking-bikes/trekking-4-lowstep-gbx007?id=45096146
It also feels a bit wobbly when I slightly turn the handle bars left and right quickly while cycling. Is this bike safe to use or is it mostly for just riding around the block with the kids? There are also lots of damaged roads with bumps etc where I ride. Is it safe to ride at high speeds on such roads? Can I fall, will the frame last etc? I also read that sometimes step through frames are not even meant to be used outside, is that true?
Thanks,
Mike
