angeloz
  1. It works! Thank you very much!
  2. The speed is quite precise when the engine is running slowly. The number of magnets is set to 1 Yolin YL80C Settings: https://drive.google.com/file/d/1xG0ZWudARO5P_l3ei6vEvSKteSwduviV/view?
  3. Video where you can see the problem https://drive.google.com/file/d/16vWNbuZY22YRPPouugpNQp1e_q0InPl0/view?usp=sharing
  4. I'll buy a multimeter. Is there any other solution I could try? Thank you very much
  5. I replaced the controller, because the display (Yolin yl80c) was limited in settings. Now, I have all the settings but I have this problem. If I put the old display and the old controller back, everything works
  6. Hi, I have an Engwe C20 Pro. I changed the controller and display. I chose those from Engwe Engine X. and in addition, I also purchased an engine hall cable. I assembled everything. Now, the problem is that with the white cable inserted, the accelerator does not work well and the speedometer fluctuates. When I accelerate, the accelerator does not give full throttle. After accelerating briefly, it stops. I was wondering why this malfunction. Maybe I have to insert the white cable elsewhere. The original controller of the C20 Pro was different and already had the hall cable as in the photo. If I disconnect the white cable, everything works perfectly but the odometer doesn't work. .
