Silvanien
  1. Hi, I took the time to think about it ! The KT controller will be compatible with the brushless motor? I also need to find one with torque sensor instead of PAS one ! I need to look a bit more, I found this one but I have to check more precisely ! https://fr.aliexpress.com/item/4000038619326.html?gatewayAdapt=glo2fra
  2. Thank you for the answer. I didn't find any compatible display... I don't know what to do !
  3. Hello! Does anyone know if kt display are compatible with ncm c7 controller ? Connector isn't but it's not a problem I can add a new one ! Regards !
  4. I have a ncm c7, joskokt, do you have some ideas? Thank you !
