joshyorr
  1. thanks again sorry for all the questions what are your thoughts on a different controller for smoother pulling away. any type I should be looking for if possible.
  2. thanks I will have a look, do i contact Andy on here or by calling woosh
  3. you are correct just looked at one of the parts and it says 2015
  4. thanks so much that's very helpful, would a different controller make it any smoother, do you have any idea what that brown wire could have been used for or is it always surplus .are these motors any good or just old tec now thanks.
  5. wanted to make sure it was all OK before I give it to my sister, I have not fitted a throttle it came from the shop like that years ago.
  6. not changed anything it was my mums and it's been sat in the garage, just wanted to find out why it didn't set of smooth , then I found this loose brown wire and thought it must have come loose.
  7. brakes cut of fine, rides ok with pedal assistance, just jerky and stalls sometimes when setting of from a standstill , when moving throttle is fine
  8. thanks it is a woposh, so you think it's fine to tape and leave, was hoping it would fix the jerky throttle when connected to the correct place. also there's only 3 fat wires coming from the motor. could this be a reason for the throttle being jerky , feels like it doesn't know where it's meant to start off thanks
  9. hello and thanks, no pins with missing or sign's of broken wires, only started looking at the wires and saw the brown wire on its own because the bike was very jerky when using the throttle when setting off. I traced the loose wire back to the centre pin on the main display loom but I cannot see where it should go on the brushless controller.
  10. joshyorr posted a topic in Woosh Clinic
    hello hopefully someone can help me identify where this wire is supposed to go and what it does ,the brown wire.It goes to the center of the round JULet plug coming out of theJ-LCD KING METER control display.
