Katrina started following Peter.Bridge
Looking for a lightweight and compact conversion kit
Bikes are so complicated:eek:
Are there any thru-axle compatible hub motors similar to the akm-75?
You're right, All-In-One motors can be a pain to repair and replacement costs can be high. While I was looking up information, I learned that these All-In-One wheels raised a lot of funds on crowdfunding platforms in the past, but it seems like they've since faded away... It looks like only the Zehus All-In-One wheels are still in the game, partnering with some brands.
Omg, I'm going to take a look.
I've really learned a lot! Thank you very much!!
Wow! Will the OLD of 142mm also fit 20" folding bikes?
I get what you're saying. Are you saying that these types of products are prone to breaking and have high replacement costs?
Thanks for the recommendation! It's a bit heavy, though.
Gosh, why is this happening? Is it because of the quality of the battery? Or something else? I've seen the boost bike products too...
wow!!! I've noticed that several electric road bikes come with the Mahle X20 motor. It's indeed a good one, quite lightweight and compact. I'm just curious, what kind of performance does a peak torque of 23Nm represent?
I came across the akm-75 motor on the conversion kits forum, and it seems like a great fit for my needs with its weight and torque. However, it doesn't support thru-axle, which is a significant drawback for me. I'm curious if there are any similar motors out there that do support thru-axle? Thanks a lot!!!
I weigh 60 kg.
I've been doing some digging. For a road bike, it seems like a rear hub motor might be the better fit... I think the akm-75 you mentioned sounds pretty perfect for me! But it looks like it doesn't support the thru-axle:(
OMG, you really know the stuff! You're absolutely right, for small hub motors, weight and pedal input are crucial for those long, steep climbs. So, I'm curious, does the akm-75 do the trick for you? And that 1.44kg is super tempting!
Converting folder bike to cassette
no need to install the pedal sensor? Cool!!!
