mxlann started following Does anyone know how to unlock an ananda b5 controller? and Which controller kit do i buy?
Thank you so much!
Ive seen people with the same motor go 45-50. The lcd is showing the right speed and theres no speed limit set. I also dont think that theres a false positive since the power consumption is correct.
Alright it finally works now, but it only goes 36kmh while the motor should be capable of doing about 50. The magnet count is correct and so is the wheel size. Any idea what might be causing this?
So for kt controllers i cant use the 1t5 with red brake connectors?
No, it was just the controller
I just realised how dumb i was. I dont have a lot of experience with ebikes. I thought there was a chance it would work since the 8 pin fits in the 9 pin socket without any problems. I thought the extra socket in the 9 pin was for a throttle, which i dont have a connector for. Thank you so much helping me.
Im talking about plugging a 8 pin male into a 9 pin female. Not a 9 pin male into a 8 pin female.
I dont have a throttle and i also dont have a connector for it. And im talking about plugging a 8 pin into a 9 pin. I tried wiring the PAS in different sequences, but the error stayed. The controller did not come with a pedal sensor so i tried using it with my old one. At this point its either the PAS itself or the 1t4 cable which is 8 pin.
How could i fix the error in this case? The controller i have has a 9 pin motor cable, 9 pin 1t5, 2 pin light and 3 pin pas. The 2 and 3 pin are WP connectors. The 1t4 cable i have now does not have a 3 pin throttle though. Could it be the PAS?
Alright, so i bought a 25A sinewave KT controller and a KT lcd7c display. When i installed everything i got a throttle error and it wouldnt work. I think its because of my 1t4 cable because its 8 pin and the controller takes 9 pin. Could that be the reason?
Im not sure how much space i have, but im ok with soldering and wiring. If the controller could use WP connectors it would be nice.
Could you maybe send a link for a controller? i dont know much about which are good and which are not.
Thank you so much!
The battery can output 40A continuous. But no, there is no label indicating max current. On the display i can see the amount of watts the motor is outputting. The highest ive seen it go is something like 916 watts.
Puts out 900w.
mxlann
Joined
Last visited
