rickyboy
  1. rickyboy started following Orbea gain lights
  2. Hi I appear to be getting around 5v at the plug that goes to the light. Not sure what I should see across the pins on the light as they are connected to the led light via a pcb.
  3. I seem to be getting around 5v at the plug when the lights are turned on by the Pulsar one. When I put a meter across the light terminals I get a reading when the meter is set at continuity or 1.985 with the light swith pressed twice so effectively turning on and off. I'm not sure what to expect as there is a pcb in the circuit.
  4. Yes I have multiple sets but just get annoyed when things stop working. I can't leave as is.
  5. It's a few years old but not used much. The iwoc instructions are confusing but may not even be relevant to the Orbea Gain. They should come on when the bike is powered on as long as the actual light switch is on. It's located on the side of the front light.
  6. Hi all, my integrated lights are no longer working on my Orbea Gain. I notice that the lights are supposed to be controllable using the iWoc controller. However, following the instructions does not work. I say short press the button then when flashing press and hold until yellow. This should toggle the lights on and off. The problem is I don't know if the light is on or off at the actual switch on the side of the light! I don't seem to have time to toggle it while the iron is yellow. Any help would be appreciated.
