B&M dynamo lights
Old school Raleigh Dover. Shimano dynamo hub with B&M lights. Rear Light (Toplight) works only intermittently. Can measure 20 - 150 mV at rear terminals. New rear light fitted but no improvement. Have checked connections etc. I have no real knowledge of electrics so any help will be much appreciated. Thanks.
pedelec battery choice
Had a similar problem last year. Bought a 24Ah Derby cycles battery from Germany. If it loses a proportion of its capacity each year, it should still be useful after 3 or 4 years. 18Ah for 325 Euros, not such a good deal since the devaluation though... http://www.akkurad.de/de/akkus/akkus-panasonic-26-v/18-ah-akku-panasonic-e-bike-motor-26-v-neueste-technologie-baujahr-2016 50 Cycles taking the piss.
Panasonic
Just an update: I removed the contact plate and found that due to heat the negative contact terminal had sunk into the plastic. So I removed the contact using a hot knife and reset it with a lot of superglue. It works, the bike lives again and I am very relieved. Thank you Flecc.
Panasonic
The battery is 2 years old (24Ah Derby). After cleaning the contacts the engine still does not start. It was the same with my second battery. Will contact Raleigh. Will also try eBay but this motor seems to have dropped out of sight. I feel rather sad about it!
Panasonic
Sage advice to check the battery contact. I found this, with a small (corroded/singed?) neg terminal and some slight heat damage of the black plastic surround at the battery terminal. See photos. Repairable? Can I find a new battery contact platform?
Panasonic
My much used Raleigh Dover has developed an electrical problem. It switches off intermittently and comes back on after a few minutes. From my reading I gather that this is unrepairable and I need a new bike. Is that correct?
Raleigh Dover sprocket and chainwheel
In process of replacing the sprocket and chain wheel on my Raleigh Dover. Thought it would be 41/19T so ordered those. Find out that is in fact 35/20T. Last replaced by Raleigh ebike shop so pretty sure they used correct ones. Have had to buy 35T chain wheel from Germany. Annoying.
"Sorry, he has a problem with his eyes!" says the passenger.
Hey, I am on your side! When you turn right in to Robertson Road it is difficult to see up Millers Road - the direction you were coming from. That is the 90 degree bend with poor visibility. I make that turn every day. I bet you will ride down that road more slowly next time. I will certainly turn right even more carefully - wouldn't want to end up on Pedelecs.
To be fair it is an extremely difficult corner. The driver was making a right hand turn up a steep incline from a stationary position. The road ahead of him turns 90 degrees left, uphill, with visibility for about 15 yards. I always expect someone to cut in front of me when I go down that hill. He is still a poor driver but you didn't give yourself much of an opportunity to stop.
Which bike?
Hills and trailers will drain your battery quickly. For best value, consider converting a regular bike: http://eclipsebikes.com/bafang-8fun-bbs01-drive-250w-motor-p-1102.html
Cheapest Bosch bike?
There is an issue with replacement battery costs. I have just received a 24Ah 26V Derby cycle battery for my old Raleigh Dover. €620 (£450) including postage. Arrived after two days by Parcelforce with the correct packaging and labels. £695 was the cheapest I could find in UK. Is it really worth £250 to have a UK supplier?
Advice for a heavy rider
This post asked for advice for a heavier rider - something I have a lot of experience with. It is not really an issue of the motor but the wheels. Most cheap, machine-made wheels will break if you are too heavy or the road is too rough. I had to resort to getting a rear wheel made (touring rim, extra-strong spokes etc). It cost £90 and I have not had a problem since. Other changes I made include a wide saddle, a mirror, a pannier rack and good lights. I ride across the South Downs and I couldn't do it without a crank-drive ebike. I find that I can do it two or three times per week but I don't want to do it every day. Oh....and it is fantastic,
advice on tyres?
A bit late but don't forget this wonderful Dutch company... http://www.dutch-perfect.nl/images/stories/brochures/DP-brochure-engels-2010.pdf
Introduction
Sussex Downs Hi, I commute from Brighton to Haywards Heath two or three times per week, a 25 mile round trip. The hills are just too steep and too numerous to manage on a regular bike and also do 10 hours work. I have a Raleigh Dover which is fantastic. The crank drive motor works through the gears and hill-climbing is superb as a result. If hills are a problem, crank drive motors are preferable to hub motors. Kalkhoff is one major manufacturer that makes several different brands. They are expensive new but plenty on EBay - just be aware that specification changes every year. AtoB magazine is very helpful.
Some questions from a new Kalkhoff pro-connector
Similar problem with my Raleigh Dover. Bought this adapter for 99p and use my old high pressure pump. Will change to Schrader eventually when I replace tyres. Weldtite Presta/Woods to Schrader Valve Adapter
rolando177
Joined
Last visited
