gcebiker
  1. Throttle incorectly supplied Hi, you have hit the nail on the head, wuxing make a range of throttles to go with many types of kits. One of my bike kits will run on 24-36 volts ...as yours does by the sound of it. so your Throttle will show out when you are using a 24v pack....alternatively if you are running on a 36volt SLA pack then the cutoff your contrller has preset will be far to low for a 36v pack...as it is designed for a 24v pack with a cutoff somewhere around 22volts. I am today changing one of my ebikes to a twist grip with no leds and found that i will have to change the hall effect sensors over as well...wuxing use different ones to the standard no led scooter throttles i have laying around. Cheers
