Everything posted by Kramer
Battery problem
maybe I didn't put it right. There are 50 cells altogether, in 10 strings. 2 dud strings = 10 cells.
Battery problem
It is. I'm getting 0v on all ten of the cells.
Battery problem
No loose wires.
Battery problem
Thanks. I thought that might be the case Hopefully it is just loose wires as you suggested. A job for tomorrow night. Will keep you posted.
Battery problem
There are 9 pins on the adjacent connector Readings are as follows: - 4.0 8.3 12.5 16.7 16.7 21.0 25.2 29.4 29.4
Battery problem
Red 1: 33.2v Red 2: 33.2v Black 1: 33.7v Black 2: 33.7v
Battery problem
Yes I did, and still zero. Apologies, charge mosfet? What does that mean, and is that it for my battery?
Battery problem
41.6v The charge socket did show zero. I followed the wires from the socket (two red & two black) back to a terminal on the BMS (see below). There were no fuses between the socket and the BMS. I tested the voltages between all combinations of the pins the red and black wires went to and again, zero. Photo
Battery problem
The charger went red for a while, but has now returned to green. I'll leave it overnight and then do as you suggest
Battery problem
What if the charger is already green?
Battery problem
OK, I'll stick it on charge again. How long do you suggest I leave it for?
Battery problem
It's fluctuating between 33.4 & 33.5
Battery problem
I charged it before I posted this thread. Do you mean differently?
Battery problem
No, it surprised me too. Not 100% sure where you wanted me to short the switch so exposed the terminals on the switch and stuck a small bolt between them. Still no reading on the output. P.S. USB socket provides power but battery indicator light on side of case shows 1 of 4 LEDs.
Battery problem
Photo 3 Photo 4 Yes, and on all the time.
Battery problem
Photo 1 Photo 2 d8veh, if you need any different angles or close ups let me know
Battery problem
The centre of the button is recessed in the on position and returns to flush with the outer ring in the off position
Battery problem
Imported from China
Battery problem
So, my ebike won't turn on as it's getting no power. My battery, which is of this type (below), appears (I will admit to not being an expert here) to have a problem with the on/off switch in that it illuminates for a few milliseconds as the button is depressed, but doesn't stay on. There is also no voltage reading at the power terminal. http://g04.s.alicdn.com/kf/HTB1MFV6FVXXXXXGXXXXq6xXFXXXK/221513156/HTB1MFV6FVXXXXXGXXXXq6xXFXXXK.jpg Any suggestions as to what I should do next to determine where the problem is as my electrical knowledge is poor at best?
Bike stuff in Lidl
You did put Thursday though, so have another one on me.
Wiring up lights to ebike battery - any tips?
With the proliferation of USB sockets on bottle batteries these days, can anyone recommend any lights that could be hooked up using the USB socket?
What Marathon Tyre do I need ?
This ebay seller has quite a few different selections.... http://www.ebay.co.uk/usr/hopkinsoncycles-2008 ....including the 26 x 1.5 road tyres I just bought: - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=231062244908 Slightly cheaper than wiggle too if buying in pairs
Anyone feeling flush ?
Some rich parents you've got there! £5k+ for a 12th birthday present.
8 fun bottom bracket motor
Try here: - http://bit.ly/1ieks9D or more seriously, try these: - http://www.bmsbattery.com/central-motor/629-48v350w-bbs01-bafang-central-motor.html http://www.greenbikekit.com/36v-250w-8fun-bafang-motor-bbs-01-central-driven-motor-electric-bike-kit.html http://www.ebay.co.uk/itm/Ultra-Fast-40KM-H-250W-350W-Mid-Placed-Electric-Bike-Motor-Conversion-kit-/221380406860?pt=LH_DefaultDomain_2&hash=item338b4cee4c http://www.aliexpress.com/wholesale?SearchText=bbs-01 350W 36v&catId=0&initiative_id=SB_20140312125212
bicycle sidehack
Me neither. d8veh, are you being serious?
