edriver
  1. It still took him some time though.
  2. If you have three cogs can you keep them or do you lose two when going for crank drive?
  3. It's x2.0 so I guess it should work then, thanks.
  4. If I decide to go for a motor+wheel option, doesn't the rim width matter? I have a tire, how do I know its width will match the rim's?
  5. Goal: speed up to 35 km/h on flat ground. Want pedal assist as well as "moped mode". Range at top speed at least 25 km. 28 inch wheels, total weight about 100 kg. No steep hills. Are these components well balanced for this task? 36V15Ah Li-Ion Battery 36V15Ah Li-Ion Alloy 03-CASE EBike Battery Pack With a Carrier Rack - BMSBATTERY Bafang CST 36V500W engine Bafang 36V500W CST Rear Driving Hub Motor - BMSBATTERY S12P 750W Torque Simulation Square Wave Controller S12P 750W Torque Simulation Square Wave Controller - BMSBATTERY S-LCD1 E-Bike LCD Meter S-LCD1 E-Bike LCD Meter - BMSBATTERY
