ibby
  1. Hello My pro-connect couldn't have been easier to assemble, if you can call it that. All I had to do was adjust the seat height, screw on the pedals, charge the battery and align the handlebars. Couldn't have been easier .
  2. Hello Have a look at the valves thread for the woods prob. Went to get my adapter and the bike shop also said change over to Schrader valves asap. May regret it but going to stick with what I've got for time being, but got adapter. However do think it may be helpful if 50cycles changed to a more customer friendly inner tube/valve. Ibby
  3. Hello A rather "thick" question but is a presta valve the same as a woods value? Just wanting to get a CO2 pump for new pro-connect- looking at a Innovations Proflate Pump. ibby
  4. I got a phone call to say mine was ready :D but it is only a little 45cm . The best things come in small packages.
  5. Thanks for all the suggestions it has been really helpful, think it will be the Pro-Connect as I'm just too small for the Wisper, but would have liked that initial power at lights and the dreaded roundabout.
  6. Continuing with the thread, I also can't decide between the two bikes however I have the added prob of only being 5' 2" so will I be able to touch the ground with my feet? Also which size of Kalkhoff 45cm or 49cm, didn't like the fact if I remember correctly that 45cm has smaller wheels, had visions of a Raleigh shopper look . This will be my third electric bike and I commute daily don't really need help with the cycling as relatively fit just like to be able to get away from those car maniacs on a particularly bad roundabout
