mumbles
  1. Thanks d8veh. Sounds like you are the resident guru on these forums.
  2. Hey Peerjay, I'll take em. Give me a PM to sort out the details. (just to check, I have twist shift gear changes, will the breaks be compatible with this?).
  3. Hey Guys, Isn't 380wH higher than the rated capacity on the battery? I understand that manufacturers often pack batteries to label + say 10% so they always hit their stated capacity, and the capacity test isn't an exact science, but I would of thought the battery would be hitting around 320wH. Think dave has already answered the query really, with the sag in voltage. The continuous current is a bit confusing with the drop in voltage? Any way sounds like its sound to me if it ran those bulbs for a decent amount of time. Cheers.
  4. Is there anyway you could test the battery for capacity left/range?
