rikki greenfield
  1. Yes he is the chap I was looking for INSAT he did mine a few years ago when it was called INSAT
  2. Just had a look on their site but states use our brand of battery would rather know what batteries were being used
  3. Last time around 6 years ago was done by a father and son team (were told the best at the time with a waiting list) cannot find details now . Can anyone think who they are regards
  4. no luck yet The PAS that I have I fitted to the old controller but it was 12v does make it hum at certain points Have ordered another so will wait Got one of those control testers and all seems ok but no way I can see to test the pas regards
  5. Cheers Will have a go tomorrow regards
  6. Thanks Its a Brainpower with lcd off Amazon For Ebike Motor Controller LCD Display Kit, 24V-36V/36V-48V Brushless Electric Motor Controller with Waterproof LCD Display Panel Set for 250W/350W Ebike Brand: Eboxer When I joined the intelligent recognition wires the wheel did turn So should I try swooping the 3 phase wires regards
  7. If I can pick your brains again I dd connect it and now fitted new controller and all I get is a buzz from hub have I damaged the hall sensors The LCD panel S866 shows E07 thanks in advance
  8. Unable to get rest of it at moment but as its a German bike Pedelecs german site could find no info so am now going to change controller to suit PAS regards
  9. The only thing is the original one on chainset is an optical sender but I would have thought the voltage would have been same?
  10. Cheers So was it possible that the out put on this controller should be 12v to the PAS as I said all the pin-outs I have found for controllers show 5v regards
  11. Need help please I have a Saches Elobike 2 which I have had since new 2010 and am now fitting a KT-V6 P.A.S On checking voltage from controller to PAS its showing 12 volts not 5 volts shown on all the drawings I have found on the web My meter shows 40 volts out put on battery The bike was working OK before I started this job just that chain set has had it and original PAS was built into it Any ideas welcomed
  12. Can I do a straight swop to a brushless hub from a brushed hub thanks
  13. Hi does anyone know handle bar and riser size thanks
