Motor going backwards all of a sudden?
Hello all! I built my bike about 4 weeks ago and everything was going well so far. I used this kit (the 48v 1500w model): https://www.aliexpress.com/item/1005003495298236.html?spm=a2g0o.order_list.0.0.2f351802lhgfzN However, the motor has decided it now wants to go backwards! I presumed it could have been a problem with the throttle wiring as I'd recently changed to a thumb throttle, so I wired the grip throttle back on but it still has the same problem. I checked the PAS, so I put it into PAS only mode, and it still has the same problem. It was all working fine and then one day, it decided to go in reverse! Is there something silly I'm missing here? Images attached, video below
Throttle lost its springosity. Acting strange
Darn! Strange that its damaged. I didn't apply any excessive pressure to it when tightening the handlebar. Bike has never been dropped or bashed (yet!). I'll contact Andy at Woosh and see how much they are. Will probably wait until after Christmas when funds have been replenished. Thanks all.
Thanks Trex, once again! I will give it a go tonight
Hi all, Woosh Big Bear rider here. Riding to work today I noticed my handlebars were a little loose so I pulled over and tightened them up. After which my throttle has lost a bit of its springiness. When I engage the throttle (pulling it towards me) it still works fine, but doesn't feel the same and it doesn't snap all the way back into position. Also, when I push the throttle away from me all the way, it engages slightly and the motor seems to receive about 10%-20% power. Which can be quite dangerous if standing still at traffic lights and I apply some pressure forwards on accident. Basically, my question is, is this an easy fix? How would I go about rectifying this issue? crE
Bosses for Big Bear Front Vs
Andy says they are 8mm. Hopefully third time lucky!
Those attaching bolts arrived but they are way too small
:o really? Where would I find such a thing??
I took it to my LBS but they said they didn't have anything and couldn't find anything on the net. The fork is top gun: http://wooshbikes.co.uk/2014/bigbear/bigbear-6-800.jpg
Inner tubes.. Am I going mad?
Ahhh. I took it for a test ride and it works fine. No bumpiness or anything. Any problems if it is actually the wrong tube? The one that was in there originally looked the same size when compared
Hi all I am wanting to install V brakes on the front of my woosh big bear. They aren't a standard fitting so I was told to get an m10 thread boss so I bought these http://m.ebay.co.uk/itm/200951489567?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=m&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0#vi_details They are slightly too big and won't screw in. Am I going wrong somewhere.?
Well. I fitted it anyway. And it worked fine
http://tapatalk.imageshack.com/v2/14/12/03/4d9f52dfa8abb77e44ac39659ef1e91f.jpghttp://tapatalk.imageshack.com/v2/14/12/03/d114b8150130b52b923f7edaf3e06ccf.jpghttp://tapatalk.imageshack.com/v2/14/12/03/0f9ecbef016050dc6d8f67dbfb6acfe9.jpg http://tapatalk.imageshack.com/v2/14/12/03/b4f15eefbe3896163ec2341296924c4c.jpg
375 miles need new brake pads!
No not patronising. I'm pretty new to this. I put the new pads on and they work a dream. Put pennies between the pads and the rim. Pulled it tight and tightened the brake cable. A bit of adjustment on the springs and it's all good. For now
Oh and yes. I did move the cable. Kept doing it and doing it. It was either full lock or no contact
Thanks guys. The new pads arrive today. Thanks trex on the wilko tip. When I fit them I will take photos. And will clean my rims regularly
crE
Joined
Last visited
