July 7, 201312 yr You could change the battery configuration from 24s2p (4 x 2 bricks) to 12s4p (2 x 4 bricks) to give 20aH at 50v. It would then go about 22mph for much further if you find 43 mph a bit scary, or go down to 18s2p for just over 30mph. Loads of options to get the speed how you want without having to spend any additional money.
July 7, 201312 yr Peaks at 4.5kw (45amps @ 100.6v) At 20mph it cruises at a mere 270-280w, there aren't many bikes as efficient as that. Range 17-30 miles Will climb ANY hill @ 29mph Comfortable cruising at any speed from 5mph-40mph Top speed 45mph Can be restricted by programming the speeds on the 2 speed switch. Currently set for 30mph and 45mph. That is awesome Sacko MS
July 7, 201312 yr Thanks New motor is being laced this week for the next project. http://i189.photobucket.com/albums/z313/sacko_vit/6BBB9C01-75E2-4D0F-B04C-2E410347D2BA-4506-00000340F5FC2539_zps091ee794.jpg http://i189.photobucket.com/albums/z313/sacko_vit/55FC17D6-EAE9-4A60-A5F5-DF9DA2A5D49B-4506-0000034109FD2A86_zps4090f18d.jpg http://i189.photobucket.com/albums/z313/sacko_vit/3E562041-F7DB-447C-89E3-835193CD5AF9-4506-00000341107F4797_zpsc04c1503.jpg
