Carry a passenger on my bike
With 2 peddlers an e-tandem should work quite well....
I thought about tandem and cargo bikes many times.
Unfortunatly I live on the first floor of the tiny flat and there is no way I can put a long bike in.
I can park it on the street, and that's what I plan to do on some bike, but it has to be a cheap <£100 bike
  • 1 year later...
  • Replies 88
  • Views 26.8k
installed my folding footpegs!
Next step, extent the seat post!
Looks like it keeps falling over cwah, maybe you should also fit a stand;)
I still have my kickstand purchased a while ago that've never fit my dahon:
http://www.pedelecs.co.uk/forum/threads/double-kickstand-for-my-dahon-jetstream.21705/page-2#post-273660
I'm thinking to get a welder to adjust the stand, extend it where it needs to be.
I found these 2 welders:
http://www.amazon.co.uk/gp/product/B002HMRTV2?psc=1&redirect=true&ref_=ox_sc_act_title_11&smid=A3P5ROKL5A1OLE
http://www.amazon.co.uk/dp/B00H8MZCY2?psc=1
Any idea which one would be best for long term and my type of project? One is 50% cheaper and seems to be the same as the other one but I may be missing something
The first is a gas less mig.a mig with gas would be better.The second one is a arc welder,which is cheaper to run(you only buy the rods,gasless mig wire is expensive.and a mig with gas you need wire and gas.)A mig is easier to use for a beginner. It is hard to weld thin steel with a arc welder.
Thanks what would you recommend me? Ideally it needs as compact and light as possible because I tend to move a lot and go to flat.
Then if it can weld aluminium or stainless it would be better but not a pre requisite. I need something strong and light for my bike
Mig with gas.you can buy different wire and gas for alumium.none are cheap.I would not try to weld in a flat.lots of practice on scrap before welding something you want.watch some videos on welding.
Ecosmo 20" folding tandam.£299 on eBay.http://images.tapatalk-cdn.com/15/12/23/9851f2a562da12d43dbd1e042f2e9ebc.jpghttp://images.tapatalk-cdn.com/15/12/23/70d6022a794591d59c5a2cb12819964c.jpg
Since I have a folding bike I realise that I almost never fold it. So I really need a compact bike rather than a folding one.
And no suspension at my speed in london's road is a bad idea I think
So the more expensive one is the best? Nothing better to compare for a newbie like me?
Mig with gas around £180,Can't see a cheaper one,if you could find one about £140 with a free bottle of gas and a reel of non gas wire and a reel of gas wire..don't forget a grinder with thin cutting discs and sanding discs.
