January 22, 201412 yr Hi back again Does anybody know how to setup the rear suspension spring it has a adjustable notched ring at the top I presume there is some sort of guide on setting this up or do I just leave it at original setting thanks Grahame
January 22, 201412 yr I believe you can adjust it - although haven't tried. My guess is that loosening it will result in softer suspension, and tightening it will make the suspension harder.
January 22, 201412 yr It's a pre-load adjuster. If the suspension is too soft, turn the adjuster clockwise (viewed from underneath) to shorten and stiffen the spring, and vice versa if you're light and want a softer ride.
