June 1, 201510 yr Miles from full charge to TOTALY flat about 17 miles ish. It's less than 12 months old and only fitted the throttle a few days ago but it works great as for the MPH not sure but the throttle takes me to the same speed as the pedlec on its own and flies down the road for such a tiny bike.
June 1, 201510 yr Miles from full charge to TOTALY flat about 17 miles ish. It's less than 12 months old and only fitted the throttle a few days ago but it works great as for the MPH not sure but the throttle takes me to the same speed as the pedlec on its own and flies down the road for such a tiny bike. many thanks,for the money it sounds more and more the inevitable next bike for me, is derestricting possible at all (i understand you havent done it), i have a dodgy bit of fast B road to traverse, and doing it faster than 15 is a good thing
June 1, 201510 yr many thanks,for the money it sounds more and more the inevitable next bike for me, is derestricting possible at all (i understand you havent done it), i have a dodgy bit of fast B road to traverse, and doing it faster than 15 is a good thing I have no idea if you can de restrict it but it does have a usb programming lead to the controller so it may be possible.
June 7, 201510 yr Author In the black box on the back of the bike under the battery is the controller and there is a vacant slot for a throttle I just fitted one to my hopper shopper. Just pluged straight in. Cost a tenner off ebay but we have members who have throttles for sale here in our group for that bike. Dead simple job to do. Ok, cheers for that, I will consider one of them then.
June 7, 201510 yr virtually all bikes without LCD display are not restricted, to go fast, just pedal hard, you'll get assisted all the way. You need more Amps to go fast on throttle alone. Scott clarke can confirm that by the number of Amps on the controller's label. On a 36V bike, 14A for 15mph, 17A for 20 mph, 20A for 23mph - you get the idea.
June 7, 201510 yr virtually all bikes without LCD display are not restricted, to go fast, just pedal hard, you'll get assisted all the way. You need more Amps to go fast on throttle alone. Scott clarke can confirm that by the number of Amps on the controller's label. On a 36V bike, 14A for 15mph, 17A for 20 mph, 20A for 23mph - you get the idea. Hold on. It doesn't matter how many amps you throw at a hub-motor, you can't make it go faster than its maximum RPM. It's rare to get an OEM bike with a hub-motor that's wound for more than 20 mph, so that's the top speed. A million amps won't change that. The Viking Ego has 20" wheels, so the winding speed could be less than 20 mph - probably closer to 15 mph.
June 7, 201510 yr the Amps are necessary to overcome the air resistance. The maximum noload RPM varies with the battery's state of charge, a less important factor in my view. The maximum achievable speed is somewhere around 80% of noload RPM assuming you have the Amps in the first place. If you want speed, crank drive is the way to go (BBS02 48V 500W).
June 20, 201510 yr Author Thank you everyone for your input, I have just bought a Byocycles City Speed 20 from Ebikes direct on 'sale'. I have to say I have only been out on it once and I am impressed with it. I don't have my cycle computer on it yet so I don't know how quick it is. But I have to say even in 6th gear I had difficulty in keeping up with it on the highest assist level, or the 'Wiggins' level as I now call it. http://www.e-bikesdirect.co.uk/Item/Brands/Byocycle/Byocycle_City_Speed_20_Folding_Electric_Bike.aspx I have no illusions about the bike as it is entry-level ebike and a Chinese import to boot (I think). But for £549 inc VAT I think it is a great (and reasonably affordable) route into the world of ebikes. And of course, as Ebikes become more popular, and battery technology improves the prices will come down. I have to say that I believe the future of ebikes, in fact bicycles in general are, 'Copenhagen Wheel' Shaped. https://www.youtube.com/channel/UCixGpLlbHeXodjBY1nOTm-g
March 30, 20179 yr Hi Scott I'm looking for an instruction manual for the Hopper Shopper SE - do you by any chance still have yours? Many thanks Allison
March 30, 20179 yr If you want to know anything specific, just ask. there's nothing special about those bikes that you need a manual for.
March 30, 20179 yr D8veh thanks for responding. I've ordered a replacement battery from BMBatteries (as the original was stolen) which is like this one (except 24 volt) .....https://bmsbattery.com/ebike-battery/704-36v10ah-li-ion-little-frog-ebike-battery-pack-ecitypower-battery.html. I just wondered how you fit them on and how to generally turn on and off the power when cycling etc (I haven't had an electric bike before). Also I'm desperately searching for a basket that will fit - Halfords said I won't get one to fit!
March 30, 20179 yr Could I please ask owners of folding ebikes, which one do you ride and what do you think of it? Thank you in advance. Hi all bikes are compromises and folders particularly so. At any price point the fittings will be lesser than those on a fixed bike. Having said that.. a folder provides advantages also. Transport and storage. Small wheels good and bad .. good in cities more manuverable , bad on ruts Cyclists Stance compromised by the location of the hinge , does not matter over short distances but would over longer distances. The peddles, the handlebars and handlebar stem need to be adjustable in order to minimise volume and these are more expensive than on a fixed bike so the compromise will be on motor power, battery size
March 30, 20179 yr D8veh thanks for responding. I've ordered a replacement battery from BMBatteries (as the original was stolen) which is like this one (except 24 volt) .....https://bmsbattery.com/ebike-battery/704-36v10ah-li-ion-little-frog-ebike-battery-pack-ecitypower-battery.html. I just wondered how you fit them on and how to generally turn on and off the power when cycling etc (I haven't had an electric bike before). Also I'm desperately searching for a basket that will fit - Halfords said I won't get one to fit! Don't worry there will be plenty of help from the people on here when you get your replacement battery, as for the basket your better off trying a bike shop as in a local independent as they will often have more of an idea what will work for you , all the best
March 31, 20179 yr Although you've bought already, I'll chime in with a vote for the Kudos Secret. I've been really impressed with mine - I've gradually replaced some components that were wearing (pedals, brakes) but overall I'm happy with it - easily copes with a 9-mile each way commute through London, comfortable and most importantly rides like a bigger bike. Recommended.
