March 3, 200719 yr Author Yes, I appreciate that the Torq's most appropriate use is very much a power-assisted bike, not pure motor powered, and I'm sure it wasn't too happy on those gradients unassisted, its just to get an idea of the useful limits of the motor alone, taking the bike's drivetrain gearing out of the equation to allow analysis of rider & motor's separate contributions to performance of bike as a whole . I think my estimate of 8-9% for the torq + 76kg rider unassisted was a bit optimistic: with different guesstimated corrections for "drag" at the different speeds of the quando & torq (say 80W @ 12mph & 40W @ ~8.5mph) and with the peak power output @ ~475W, the predicted gradient limits for a 100kg (bike+rider) unassisted would be: Torq ~ 7.5% Quando ~ 11%+ Which, while not exactly what you have found in reality, is near enough (about 1% gradient difference) for me, as a rough guide to motor limits in each bike. Incidentally, applying the same to your case, Peter, would give (Torq @12mph): limit of motor alone ~ 6.5% limit with 100W rider input ~ 8% limit with 150W rider input ~ 9% - check my figures & take with a pinch of salt . Stuart. Hi everyone who has contributed to this discussion. Today was a day better than most for weather - Breezy, Sunny, Temp 7C. Fully charged Li-ion batteries (recharged Last Sunday) were used, stored in an unheated garage. My first tests were on a CHOPPER: Weight Bike 25 Kgs + Spare battery + Rider 90kgs = about 120Kgs 1st Hill 7% (1 in 14) Motor Cut out at 8 mph unassisted - restarted after switch off/ then on. 2nd Hill 3% (1 in 30) Motor cut out at 9 mph unassisted - restarted after switch off/then on. VERY DISAPPOINTING. It is also worth noting that even on gradients of 1% or 2% (no steeper) the unassisted road speed falls from 12.5 mph to 11mph. My second Tests were on a Torq (restricted to 15.5 mph); Weight: (more or less the same as above). 1st Hill 7% (1 in 14) Motor laboured at 8.3 mph but still produced some assistance. 2nd Hill 10% varying to 9%(1 in 10/11) Motor assisted by rider input (very slight) Lowest gear 39 inches - Cadence about 70 rpm Motor produced useful output at 7.8 mph. I had to rest every 150 metres (or so) when the red light appeared. VERY ENCOURAGING The Total Miles covered out and back on one battery (yellow light on at finish when stationary) was 18.5 miles. I was too tired to do more flat miles to see how far the battery would go. When I recover fully from the virus and get 'limbered up' I shall be able to tackle 10% grades with a rest to recover my breath (legs are OK) every 150 metres, or so. Peter
March 3, 200719 yr Hello Peter Those Chopper tests were very odd and had to be due to either dud battery contacts or a Li-ion battery problem. A correctly working Chopper would never cut on on any hill with an NiMh battery and clean battery contacts, and cut-out shouldn't be that likely with Li-ion on that model. That said, I have had similar cut-outs with Li-ion on both Torq and Quando. The drop to 11 mph is only to be expected though, as it's only geared to do just above that maximum. The Torq is as expected with that reduced gear set that's on that one. It produces around 280/300 usable watts at about that 8 mph mark, rideable with that 39" gear. A pity about that Chopper fault, you would have been quite impressed at the hill climb capability of that bike. I'm pleased that your health is now permitting you doing those tests though, good progress. . Edited March 3, 200719 yr by flecc
March 3, 200719 yr ditto Hi Pete Glad to hear you're back in the saddle in the better weather & have some encouraging results Thanks for the info. Ditto Flecc's comments re: the chopper, no personal experience but from what I've read it should be one of if not the best hub motor climbers? Li-ion, again from what I've read, not quite as effective for long/steep hills as NiMH, but all the same, results look suspect to me too... I didn't allow for your lower gearing (& possible sub 12mph hillclimbing) in my guestimate of gradient limits on your Torq, so better results at 8mph may be possible and that seems to me a reasonable compromise speed. I've just started a thread here asking how the Torq limiter may affect things like hill-climbing power output, and since you use the Torq restricted you may want to look in in case its useful to you . Stuart. Edited March 3, 200719 yr by coops
March 13, 200719 yr Author More Torq and Chopper Tests Hello Peter Those Chopper tests were very odd and had to be due to either dud battery contacts or a Li-ion battery problem. A correctly working Chopper would never cut on on any hill with an NiMh battery and clean battery contacts, and cut-out shouldn't be that likely with Li-ion on that model. That said, I have had similar cut-outs with Li-ion on both Torq and Quando. The drop to 11 mph is only to be expected though, as it's only geared to do just above that maximum. The Torq is as expected with that reduced gear set that's on that one. It produces around 280/300 usable watts at about that 8 mph mark, rideable with that 39" gear. A pity about that Chopper fault, you would have been quite impressed at the hill climb capability of that bike. I'm pleased that your health is now permitting you doing those tests though, good progress. . I have been in touch with 50Cycles (Jim) and we are working on a diagnosis of the problems. Both the Chooper and the Torq are displaying similar symptoms but the diagnosis may well be different because of the basics of each bike (the Chopper has better climbing ability because it has 20 inch wheels). Here are my test results - not entirely scientific but the best an amateur can do: E-ZEE CYCLES TESTS – 13th MARCH 2007. Rider Weight 92.8 KG (204 lbs) Weather: Dry – Sunny –Temp 10.8ºC – Wind Negligible. EZee Chopper Hill 6.5% (no variation on climb) - 260 yards long Test 1. Battery miles 3.57 Stopped at 8.8 mph unassisted Diagnostic LED did NOT flash Test 2. Battery miles 3.88 Did NOT stop – 8.5 mph to the top Test 3. Battery miles 4.23 Stopped at 8.5 mph unassisted Diagnostic LED did NOT flash Test 4. Battery miles 4.57 Did NOT stop – 8.4 mph to top Test 5. Battery miles 4.90 Stopped at 8.2 mph unassisted Diagnostic LED did NOT flash Hill 3.5% Test 6. Battery miles 7.11 Stopped at 8.8 mph unassisted Diagnostic LED did NOT flash Hill 2.5% Test 7. Battery miles 7.6 Stopped at 9.4 mph unassisted Diagnostic LED did NOT flash Total mileage 8.55 miles – Green Light on at rest – last mile stopped 5 times even at 10 mph downhill 1% EZee TORQ – de-restricted Hill 6.5% x 260 yds long 1st Test: 11 mph unassisted – stopped after 194 yds – Diagnostic KED did NOT flash 2nd Test: 7.6 mph unassisted – did NOT stop – Red Light on at 17 mph 3rd Test: 8 mph unassisted – did not stop – Red light on at about 16 mph On the return journey 3.57 miles to 7.14 miles the red light was on at 17,16, &15 mph on the level road. Your views would be appreciated. Peter
March 13, 200719 yr I'll remark on the Torq first, as that is simpler. At 11 mph when it cut out, it's almost at it's maximum current drain against load situation, so that would provoke the greatest voltage drop, with cutout at about 32 volts. This is a situation I recognise well from my own experience with two batteries. This can happen even with a new and healthy battery if the load is applied for long enough At around 8 mph, the load has lessened and the current demand can be a bit less. In theory, the current demand will be the same, but with some of it wasted at that speed, being well below the power band, only around 300 watts are realised as usable power, so tolerances or resistance could make the current drain fall just short of cutout point. The Chopper situation is much more difficult to judge. It seems it's marginally near to cutout all the time, and the characteristics suggest chemical exhaustion. It may be that one cell is failing in the affected batteries, this being enough to cause this sort of failure on such low loadings, but equally there might just be a slight controller problem, since the results don't quite fit what's happening with the Torq. It may be that it's cutting out too early. On the first battery that started to fail for me, it behaved just as badly in the Quando as in the Torq, despite it being the better hill climber as with your Chopper model, and that became unusable in the end, even for the shortest journey on either bike. Since I had an NiMh battery as well, I was able to satisfy myself that the bikes were ok, and that is was solely the battery at fault. Therefore I still favour it being at least one battery problem. The Li-ions can show some inconsistency. 50cycles kindly replaced the faulty battery for me, and after that was run in, on a long climb up the downs, it cut out towards the end. As usual then, it cut out three further times before I reached the top, this being due to the fact that time is needed to recover from chemical exhaustion. If I'd waited 15 to 30 minutes after the first cutout, it would have completed the climb without any problem. Since then it's never cut out again in either bike, showing the odd inconsistency I mentioned. .
March 13, 200719 yr Author I'll remark on the Torq first, as that is simpler. At 11 mph when it cut out, it's almost at it's maximum current drain against load situation, so that would provoke the greatest voltage drop, with cutout at about 32 volts. This is a situation I recognise well from my own experience with two batteries. This can happen even with a new and healthy battery if the load is applied for long enough At around 8 mph, the load has lessened and the current demand can be a bit less. In theory, the current demand will be the same, but with some of it wasted at that speed, being well below the power band, only around 300 watts are realised as usable power, so tolerances or resistance could make the current drain fall just short of cutout point. The Chopper situation is much more difficult to judge. It seems it's marginally near to cutout all the time, and the characteristics suggest chemical exhaustion. It may be that one cell is failing in the affected batteries, this being enough to cause this sort of failure on such low loadings, but equally there might just be a slight controller problem, since the results don't quite fit what's happening with the Torq. It may be that it's cutting out too early. Therefore I still favour it being at least one battery problem. The Li-ions can show some inconsistency. . Thanks for the quick response Flecc. I did say that the "science" of the tests were amateurish. I realize now, reading your observations: the Tests I did last week were on both bikes on the SAME battery (a Li-ion). The Tests today were done on two different batteries (both Li-ion). The Chopper and its battery have done 91 miles. The Torq and its battery have done 333 miles. They have both been keept charged up after each use whether of 2 or 3 miles or 10 0r 20 miles. Does that put a different interpretation on the results of the Tests? I did notice (but did not report because it was subsequent to those first two rides) this "recovery" factor. On the Torq: Riding a hill about 4% with me assisting in my limited way, I had the red light on. After I had stopped to post a letter (about 2/3 minutes - I wear so many clothes it takes a while to search all my pockets to recall where I put things:D ) the Green light was more in evidence and even under acceleration only the yellow light came on. But as soon as I reached another "Hill" (2%) the red light was back on until I coasted down the other side, it was back to yellow (Not green). I had a feeling it was cell exhaustion. My previous experience is only of Lead Acid Batts. When you get a dud cell it's OK when the batt. is fully charged (as fully as it can be with a dud cell) but as soon as one has given the batt. some grief as with the starter motor on a cold morning the decline in power is quite apparent. Then, after a good drive (like 40 miles) it's back so that you don't know anything is wrong until you try to start the next day and put some real load on it. Peter
March 13, 200719 yr I don't think that really alters what I've said Peter. As you've said, this is clearly chemical exhaustion, which these Li-ions show when they are under too heavy a load, or a high load for too long. The cutout guards against the first instantly, while it comes in later with the second as the high load gradually increases the exhaustion to the low voltage point. The second case is the most common, but I did get the first very dramatically with the Torq when new once. I'd pointed it at a hill which was impossible for both the Torq and me, and we both cut out together in protest! Very much an instant stop on that 20%. .
March 19, 200719 yr Author Torq - The Power to climb hills. Hi Peter, (Excuse the lateness - ......... Additionally, it would seem that roughly 8-9% for Flecc or 7-8% for you Peter, is do-able unassisted on a Torq, as a conservative estimate...? How does this compare in reality? I hope that helps? Stuart. I apologise in that I might not have acknowledged your efforts Stuart. This is the result of a test I ran on my Torq with a fully charged battery less 3 miles to the test ground: EZee TORQ - de-restricted Hill 6.5% x 260 yds 1st Test: 11 mph unassisted - stopped after 194 yds - Diagnostic LED did NOT flash The motor was derestricted. 'Stopped' means the battery cut out. See my profile for personal data. I am going to find a 5% hill for a test run as soon as the weather improves Thanks Peter
March 20, 200719 yr Re: Coops quote entry Peter, that Torq climb figure from me was a theory one, I've previously stated that in practice the Torq will barely scrape 7% with a battery straight off the charger, and only 6% is moderately manageable. So your result on 6.5% is quite normal. .
March 20, 200719 yr Author Torq on hills Re: Coops quote entry Peter, that Torq climb figure from me was a theory one, I've previously stated that in practice the Torq will barely scrape 7% with a battery straight off the charger, and only 6% is moderately manageable. So your result on 6.5% is quite normal. . Thanks for that Flecc - since I became fixated with the trouble with the Chopper and its battery, every time the Torq stops I get very nervous. With so many variables (particularly with the riders) there seems to be no normal range of behaviour on hills. So if the motor unassisted cuts out on hills 6% or above - taking into consideration Health, Age and Strength (see my profile) I propose not to worry. Anyway, there's always the flat. Peter
March 20, 200719 yr One final note on the Quando re: our discussion on gears Peter. I've had the Quando rear wheel out as I had a suspicion about the freewheel. My suspicion was correct, it's a BMX freewheel with it's smaller thread size, so a multi sprocket freewheel isn't an option, it's stuck with single speed. .
March 20, 200719 yr Hey, don't worry Pete I just hope you find a bike solution which meets your requirements. As has been said those figures are at very best only a rough guess, and performance will vary according to level of battery charge etc. etc.... besides, the Torq is I think best used while pedalling. How's the battery situation now? Did you try the Chopper on your hills with the ok battery, or was that never an option? Stuart.
March 21, 200719 yr Author Chopper Test Hey, don't worry Pete I just hope you find a bike solution which meets your requirements. As has been said those figures are at very best only a rough guess, and performance will vary according to level of battery charge etc. etc.... besides, the Torq is I think best used while pedalling. How's the battery situation now? Did you try the Chopper on your hills with the ok battery, or was that never an option? Stuart. The more I learn about these bikes (Torq and Chopper) the more anxious I get. It comes from having feeble legs (see my profile) so even pedalling will not make up the neccesary difference to surmount the obstacles in my path. No, I did not try the Torq with the Chopper's battery (yet), nor the Chopper with the Torq's battery. I must do that: it will tell me a lot. I was on my way to my nemesis (Shaftesbury Hill from the east A30 = 10%) when the "whatever it was" died on the 6.5% hill half way to my project. I tried the hill seven times (without assistance to test the theeory that it would climb almost anything [a garage wall was mentioned at one point but I think that was a motor driving chain, driving cassette 12 - 32 teeth]). Naturally I was disappointed with the result that I did not get up 5 times out of the seven. For my next trick I took the Torq out unlimited and performed the same test. The motor stalled at 11 mph on that hill 6.5% x 260 yards when I reached 194 yards. Here are the full result of the tests; E-ZEE CYCLES TESTS - 13th MARCH 2007. Rider Weight 92.8 KG (204 lbs) Weather: Dry - Sunny -Temp 10.8ºC - Wind Negligible. EZEE CHOPPER Hill 6.5% (no variation on climb) - 260 yards long Test 1. Battery miles 3.57 Stopped at 8.8 mph unassisted Diagnostic LED did NOT flash Test 2. Battery miles 3.88 Did NOT stop - 8.5 mph to the top - unassisted Test 3. Battery miles 4.23 Stopped at 8.5 mph unassisted Diagnostic LED did NOT flash Test 4. Battery miles 4.57 Did NOT stop - 8.4 mph to top - unassisted Test 5. Battery miles 4.90 Stopped at 8.2 mph unassisted Diagnostic LED did NOT flash Hill 3.5% Test 6. Battery miles 7.11 Stopped at 8.8 mph unassisted Diagnostic LED did NOT flash Hill 2.5% Test 7. Battery miles 7.6 Stopped at 9.4 mph unassisted Diagnostic LED did NOT flash Total mileage 8.55 miles - Green Light on at rest - last mile stopped 5 times even at 10 mph downhill 1% EZEE TORQ - de-restricted Hill 6.5% x 260 yds 1st Test: 11 mph unassisted - stopped after 194 yds - Diagnostic LED did NOT flash I could not have caught the Key (that can happen but not recently) with my heel 'cos I was not pedalling. 2nd Test: 7.6 mph unassisted - did NOT stop - Red Light on at 17 mph 3rd Test: 8 mph unassisted - did not stop - Red light on at about 16 mph On the return journey from 3.57 miles to 7.14 miles (on the computer) the red light was on at 17,16, & 15 mph on level road After all this I was too bushed to do any more - I recharged the batteries - sent details of the test to Jum at 50 Cycles- and cooked dinner. The weather on the Wednesday 14th March had changed for the worse - no biking! Cheers Peter
March 21, 200719 yr I've read somewhere on this forum about some of the different characteristics of Li batteries, especially on hills, so that's one possibility. If I find the thread, I'll link to it from here. Since Jim at 50cycles is dealing with this, I wouldn't like to suggest anything which might interfere, but to me common sense would dictate to firstly check if both your Li batteries are performing similarly and also to make sure its not a poor battery connection in the Chopper. Maybe charge both batteries & check voltage of each when fully charged, meanwhile ensure battery contacts are dry & clean in both bikes (tips aplenty from Flecc). If you suspect one battery performs poorer than the other, try the better one in chopper in particular, to see if that improves performance. Hope that helps Pete P.S. Don't know if you saw my suggestion in your "index for threads" thread, so just thought I'd mention it here for you .
March 22, 200719 yr Author Battery versus Battery I've read somewhere on this forum about some of the different characteristics of Li batteries, especially on hills, so that's one possibility. If I find the thread, I'll link to it from here. Yes please. Since Jim at 50cycles is dealing with this, I wouldn't like to suggest anything which might interfere, but to me common sense would dictate to firstly check if both your Li batteries are performing similarly and also to make sure its not a poor battery connection in the Chopper. I cleaned the Battery contacts, on the bikes and on the batteries on our return from a somewhat damp ride with Methylated Spirits. Jim has telephoned Ezee in China but his contact could not provide a diagnosis He has asked me to send the Chopper battery to him for testing but that is difficult because the Post Office/Parcelforce will not accept batteries for carriage. Here is a quote from Parcel Force Conditions of Carriage General prohibitions and restrictions. Some things we can't deliver: Parcelforce Worldwide complies with strict transport regulations. We will not carry certain goods and substances. Please check our guidelines on prohibited goods before you arrange dispatch Class Eight: Corrosives: Substances which can cause severe damage by chemical action to living tissue, other freight, or the means of transport. All corrosive substances are prohibited. Examples: Aluminium Chloride; Caustic Soda; Corrosive Cleaning Fluid; Corrosive Rust Remover/ Preventative; Corrosive Paint Remover; Electric Storage Batteries; Hydrochloric Acid; Nitric Acid; Sulphuric Acid, etc Maybe charge both batteries & check voltage of each when fully charged, meanwhile ensure battery contacts are dry & clean in both bikes (tips aplenty from Flecc). I fully charged the batteries on return from the tests. I checked the Voltage output of each. The Chopper battery showed 40 Volts and the Torq battery showed 42 volts. I will clean battery contacts, both on the bikes and on the batteries before I make the next tests If you suspect one battery performs poorer than the other, try the better one in chopper in particular, to see if that improves performance. This was my intention: by the time I had finished those first tests I was bushed (partly nervous exhaustion). The weather then changed for the worse. I am awaiting better weather: hopefully the weather for the next tests will be much the same as for the first tests. Hope that helps Pete : Everything helps when one's batting in the dark! Peter
