Bosch performance CX ratio
Hi.
I am looking at a Cube bike with Bosch performance CX drive unit and would like to calculate driving speeds for different gears and cadence.
The problem is I can not find out what the ratio between pedal RPM and sprocket RPM for Bosch CX drive is?
Thank you for any info!
2,5 is the ratio, so a 16 tooth sprocket gives in effect a 40 tooth front sprocket.
Great! I could not find this anywhere! Thank you!
Glad to see I will not have to pedal like crazy to go 20mph. :)
