July 16, 20178 yr I read about the whole turn left to go right thing last week and i just don't get it,I tried it but as far as I can see if I want to go right I turn the bars to the right Ride along with the palms of your hands on the top of the bars and your thumbs behind the grips. Push forward with one thumb and see what happens. Don't do it close to the kerb!
July 16, 20178 yr I will try it tomorrow and report back my findings,my brother tried to explain it to me (motorbike rider) but.................
July 16, 20178 yr I will try it tomorrow and report back my findings,my brother tried to explain it to me (motorbike rider) but................. Anybody can explain it, but it's counter-intuitive, so understanding the explanation isn't easy. You need to understand how angular momentum works and how it's affected by torque. Even many engineers and scientists don't get it, so it's nothing to be ashamed about. When you try what i suggested, it'll make a lot more sense.
July 16, 20178 yr I don't know if people find it counter intuitive by this video makes it clear: you only need to countersteer to initiate the turn. After that, your body and the bike lean into the turn. Anyway, that's how most kids do slalom around traffic cones.
July 16, 20178 yr Three eee (or however you spell/saythat) Urban bike has three or four broken spokes from heavy weight son bumping up and down kerbs (I suspect). Can anyone please tell me where I can get new spokes? Local bike shop is at a loss. I seen some on eBay but you need to find out what size they are
July 17, 20178 yr Ok I tried the method described by d8veh and when going slow it does indeed work BUT when riding along normally I don't notice any counter steering happing,it could be happing quicker than my brain can notice it though.
July 17, 20178 yr Ok I tried the method described by d8veh and when going slow it does indeed work BUT when riding along normally I don't notice any counter steering happing,it could be happing quicker than my brain can notice it though. in physics, the bike will steer itself in the direction of your line of gravity. If your line of gravity goes over the centreline, the bike will go straight. If your line of gravity is to the right of the bike's centreline, the handlebars will turn right. Countersteering has two stages, in the first stage, you initiate the turn that causes your gravity line to move to the side you want to go.Then in the second phase, gravity and inertia turn the handlebars for you. The word countersteering describes accurately the sensation you feel in your wrists, because when inertia turns the handlebars, it tends to turn more sharply than you want to, so you have to control it, in effect, by continuing to countersteer a little. The front wheel will of course turn with the handlebars and the bike will follow the front wheel. On an e-bike with thin tyres, the required effort to steer the bike is very little, you don't feel much the countersteering force, on a fat bike, you will feel it more. .
July 17, 20178 yr It's the other way round. If the front wheel is rolling forward, the direction of the angular momentum vector is to the left. When you apply torque to the handlebars as if to turn them to the left, the direction of the torque vector is upwards. The torque therefore has the effect of trying to pull the angular momentum vector upwards as if the axle was extended to the left and you lifted up the end. This makes the wheel precess (tilt) to the right. Basically, that means that if you push the bars to turn them to the left, instead of them rotating, the bike leans to the right. That's what you need to initiate the turn. Once you are tilted over, you balance that by turning in a circle, otherwise you'd end up flat on the floor. When you've turned enough, you push the bars the opposite way to bring the bike back up vertical again to go straight. So, the handlebars do not control the steering when the wheel is spinning. Instead they control how much the bike leans. That's why when you spin up a wheel and hold it by its axle, it seems to go all over the place out of control. It's because the direction the wheel goes is always at right angles to the direction you try and move it. When you understand that, you can control it perfectly. That's the bit that people struggle with because nearly everything in life will go in the direction you push it, but if it's rotating, it goes at right angles to any torque you apply.
July 17, 20178 yr you make it more complicated than it is. You can of course steer the bike like a car if you so wanted. You can also use the countersteering technique to do the same with less effort, Inertia is what make the bike tilt. When the bike tilts, the front wheel is pitched and turns because of its gyroscopic precession and the bike turns, following its front wheel.
