Dealing with Yamaha lock nut
So I removed my cranks from my haibike all mtn sl 2016 and discovered theres some sort of lock ring stopping me taking the chain ring off. It looks to be roughly 1.4 inches in diameter. Does anyone know how the heck I can remove those so I can replace my damaged chain ring? Its sort of recessed into the spider, which means I cant get a wrench onto it :(
Its a completely different shape to the bosch one. Im going to see if i can get my hands on a 35mm socket for torque wrench. Its basically just a hex nut by the looks of it.
you will need to hold the crank arm on the other side or if the chain is on pull the back brake so you can unscrew it.;)
  • 4 months later...
