Will the freego raptor controller handle a 36v battery?
Hi all,
Please help me!
I have a freego raptor (24v) which I use for my daily commute. The battery is not performing like it used to and tends to run out now just before the last hill on the way home.
I have access to 36v 13ah battery from a conversion kit I bought before i got the raptor and it is still in good order.
I was hoping I could use the 36v rather than shelling out on a new battery. As the controller is located inside the frame I am not sure how to get at it to see if it will handle 36v.
So the questions are;
Does anyone have any idea where in the frame the controller is mounted and how you access it?
Does anyone already know what controller is in a freego raptor and whether it would be rated for aa 36v battery?
I guess this may push the speed beyond legal limit so i am hoping that i can limit the speed somehow through programming the display / controller.
If the controller already has a speed limit, changing the battery to 36V won't change it.
I never heard of anybody trying a 36V battery with one of those bikes. Most 24V controllers can take a 36V battery, but there's no guarantee. If it does blow, you can get a normal 36V controller and LCD and run the wiring external to wherever you mount the controller. Alternatively, you have to remove the 24V controller and check what components it has.
  • 9 months later...
The controller is in the seat tube. Also did you try it?
Edited by Staps
