February 20, 20206 yr Ianb11 submitted a new listing: [plain]Riese and Müller Delite GT Nuvinci[/plain] - [plain]Riese and Müller Delite GT Nuvinci[/plain] It's time to upgrade to the 2020 model hence the sale. I took delivery of the bike new in August 2017. I have the original purchase receipt, all original documents and three Abus keys for the Bordo lock and battery lock. Note these are keyed alike so the same key fits both locks. There is a slight abrasion on the end of the left-hand Ergon grip. There are also abrasions on the rack pannier supports from the panniers rubbing against it. (can be seen clearly in the photos). The bike is in... Learn more about this listing...
February 20, 20206 yr Author Sorry, I realised about an hour ago that I had missed out this important information. It's 49 cm. Here's the full spec. Headset: Acros AZX-220, tapered, block lock Seatpost: Satori Trident Seatclamp: Kalloy SC-201, 40,0 mm Tyres: Schwalbe Super Moto-X 62-584 Reflex Rims: Alex MD40, 27,5" Spokes: Sapim Leader 2,0 mm, inox ( 16x ) Front hub: Novatec, QR Crankset: FSA/Riese & Müller, 170 mm Chain ring: 26T, for Gates drive belt CDX Chain guard: FSA W1129 Chain: Gates drive belt CDX Pinion: 28T, for Gates drive belt CDX Saddle: Ergon SMC4-L Gel Pedals: VP-191 Shifter:NuVinci N380 grip shift, continuous Handlebar:Humpert ergotec ErgoXXL, 31.8 mm Stem: Humpert ergotec Charisma, 90 mm, 20° Grips: Ergon ergonomic Front light: Busch & Müller Lumotec IQ-X E Tail light: Busch & Müller Toplight Mini LED Mudguards: SKS 65; SKS B65 R Luggage rack: Riese & Müller Kickstand: Pletscher Comp 40 Flex Lock: ABUS Bordo Plus Frame height: 49 cm
February 21, 20206 yr Buyers will be interested in the mileage and whether you are including the second battery.
February 21, 20206 yr Author Thanks. The mileage was visible on the Nyone display but I've added to to the description as well. The second battery was a £600 option on that Delite model and I didn't order one.
February 21, 20206 yr It's got the second battery tray under the cross bar so would have had a second battery somewhere along the line. The tray also includes the wiring and software which quite cleverly sips from each battery in turn when two are installed. It also charges in the same way.
February 21, 20206 yr Author It came capable but as I said, the second battery was an option then. £630. https://web.archive.org/web/20170611133148/https://www.r-m.de/en-gb/e-bike/delite/delite-gt-nuvinci/#17D10_05020719
February 21, 20206 yr Author It's got the second battery tray under the cross bar so would have had a second battery somewhere along the line. The tray also includes the wiring and software which quite cleverly sips from each battery in turn when two are installed. It also charges in the same way. Are you confusing it with the Charger? At the time that was only configured for dual batteries if you ordered it with the extra battery. Not so the Delite which came configured for two regardless. A buyer will see that the price on the invoice matched the price without extras on that archived page.
February 22, 20206 yr The only other Delite I can recall seeing didn't have second battery configuration, but that may have been an earlier one. Your bike also has the bottle cage mounting plate near the head tube, which was also an option at one time.
February 22, 20206 yr Takes a standard bottle cage. Quite handy, because one of the problems with this design of ebike is there's nowhere to carry a drink.
