September 12, 20205 yr Author Well, I know there are better bikes than this, but that doesn’t change the fact that I like my Array and enjoying every minute on it
September 12, 20205 yr Well, I know there are better bikes than this, but that doesn’t change the fact that I like my Array and enjoying every minute on it If you’re enjoying the bike then that’s all that matters, have fun!
September 12, 20205 yr Personally, if the speed sensor is something that you want 9and I do) a low range 'cycle computer' with a magnet on the front wheel is really cheap - and can be fitted in a few minutes - so I would do that and have a dedicated device rather than one linked to the BMS and motor I know that my old - and very cheap - speedometer/computer that I used before I swapped from an Array to a Motus was f more accurate and easy to use than the one on the basic motus! And anyway - you could always use a GPS speedometer ( or Strava.Endomondo etc) on a phone and be really accurate!
September 12, 20205 yr Personally, if the speed sensor is something that you want 9and I do) a low range 'cycle computer' with a magnet on the front wheel is really cheap - and can be fitted in a few minutes - so I would do that and have a dedicated device rather than one linked to the BMS and motor I know that my old - and very cheap - speedometer/computer that I used before I swapped from an Array to a Motus was f more accurate and easy to use than the one on the basic motus! And anyway - you could always use a GPS speedometer ( or Strava.Endomondo etc) on a phone and be really accurate! Agreed, pretty much everyone has a smartphone, bike mounts are cheap!
