March 3Mar 3 One doesn't open the other side, the motor core has to be extracted with a puller to over come the motor winding/magnetic force field ,. As said: the sun gear assembly won't pass beyond the ring gear that has a smaller diameter! And there is no force on the axis direction that move up and down for 2-3 mm Here are pictures of quite the same model of mine, opened on the cable side: [https://endless-sphere.com/sphere/threads/dapu-motor-disassembly-thread-on-screw-on-sidecover.114480/] Edited March 3Mar 3 by mmmx
March 4Mar 4 As said: the sun gear assembly won't pass beyond the ring gear that has a smaller diameter! And there is no force on the axis direction that move up and down for 2-3 mm Here are pictures of quite the same model of mine, opened on the cable side: [https://endless-sphere.com/sphere/threads/dapu-motor-disassembly-thread-on-screw-on-sidecover.114480/] Does that one open on both sides?
March 4Mar 4 ...and more generally, would any hub motor devotee help out this mid-drive rider, and explain whether opening both sides is normal / unusual / unheard of? My engineering brain gets unhappy considering the structural implications of both sides being separable.
March 6Mar 6 So, it appears many hub motors open on one side only. In this case the point is how to remove de gear ring! Shall it be threaded, or I have just to pul it out in some way?
