Computers and stuff...
  • Replies 1.8k
  • Views 153.5k
Most Popular Posts
  • BYD is now upgrading some of its top selling EVs with 5-min flash charging https://electrek.co/2026/04/15/byd-upgrading-top-selling-evs-with-5-min-flash-charging/
  • A 1977 Time Capsule, Voyager 1 runs on 69 KB of memory and an 8-track tape recorder Blogging Scheme A 1977 Time Capsule, Voyager 1 runs on 69 KB of memory an... Right now, more than 15 billion miles f
  • lenny
    Scientists crack a 20-year nuclear mystery behind the creation of gold ScienceDaily Scientists crack a 20-year nuclear mystery behind the cre... Gold and other heavy elements are born in some of the u
[ATTACH type="full" alt="20241103_222218[1].jpg"]60547[/ATTACH]
looks like i need another ap as got 23 devices on this one and if the bit rate of one of the cams drops below 140 it keeps cutting off :confused:
i need more power :D
[ATTACH type="full" alt="20241107_180659[1].jpg"]60596[/ATTACH]
[ATTACH type="full" alt="20241107_180752[1].jpg"]60597[/ATTACH]
[ATTACH type="full" alt="20241107_180814[1].jpg"]60598[/ATTACH]
wifi 6 it come complete with a celling mount kit for a office tile and the plastic part it clips to is missing ffs :rolleyes:
Edited by soundwave
https://www.4gon.co.uk/ubiquiti-unifi-access-point-wifi-6-pro-p-10059.html
you need a cloud key/ gateway to use them and for the cams you need one with hdd in it.
for a large warehouse id use one of these.
https://www.4gon.co.uk/ubiquiti-unifi-dream-machine-pro-max-p-10694.html
[ATTACH type="full" alt="20241108_172554[1].jpg"]60620[/ATTACH]
Edited by soundwave
i have been using this stuff since they made there first access point that you use a pc to run the controller gateway on now its a cloud key or a dream machine is it all in one unit that you log in to via 192.168.0.7 ect
the g3 cam on the back the ap has to go through 2 solid concreate walls it kicks the virgin routers ass wifi wise as never used it.
even linus tech tips uses this at work and at home but it gets a bit limited if you want a 10gb switch but they did just release a nas
https://uk.store.ui.com/uk/en/products/unas-pro
no hdd of course but will need to use a raid setup so 2 drives for redundancy if 1 fails.
and the best bit is i not got a clue about networking i just plug it in it does its thing gets adopted and just works out the box.
and you can remove remote access so only local log in or you need a ui account https://account.ui.com/
[ATTACH type="full" alt="20241108_201116[1].jpg"]60625[/ATTACH]
[ATTACH type="full" alt="20241108_201147[1].jpg"]60626[/ATTACH]
[ATTACH type="full" alt="20241108_201207[1].jpg"]60627[/ATTACH]
For cheap raid, I have a second hand hp DL380 with 10 x 2.5" sas drives. You can set the raid array to raid 5 or raid 10, dead easy on the DL380, just tick boxes with the mouse. I paid £125 on ebay for the lot. For wifi, I use a bunch of 1.3gb dual 5G sticks. They cost me £5 each. For remote access, I use tailscale. It's free. I run mostly dockers nowadays.
Those are bl**dy expensive. I use a bunch of tapo cams. They cost peanuts. They record onto microSD but you can simultaneously record using their cloud storage or you pc using onvif protocol.
